Old 2016.05.03, 02:02 AM   #1
jcstuezday
†hazel 5'7" mayan owl†
jcstuezday's Avatar
Question HPI Racing 65 Turn Stock Motor Replacement
I got a Micro Rs4.... Iz there a good 20 dolar electric 130 motor i can purchase prefalably black in color that iz faster than that motor in the title....
i do not know much about that stuf but i see a lot of 130 tamiya with diferent rpm range some 32000 some twice that....
i can shave weight and gain in speed with that motor 130 size and a motor with more power iz like the new stock motor in my micro rs4 box....
There iz a home run 78000 rpm black motor on ebay for 20 dolar....
iz that faster than the hpi....
space....
justin
jcstuezday is offline   Reply With Quote
Old 2016.05.03, 07:13 AM   #2
I used to have a micro rs4. I don't think tamiya motors are the best replacement. The best I've used was a graupner 300 speed 6V motor. Runs great and even better if you have a 7.2V battery pack. The downside though is that you have to purchase a different motor plate to accommodate the bigger motor. It's well worth it though. Do a google search and Good luck. Hope this helps.
Old 2016.05.04, 06:03 PM   #3
jcstuezday
jcstuezday's Avatar
I had a graupner 6 cel micro rs4 stock and 45t brushed....
Can any one here make a 130 motor all black and sensored with ceramic bearing carbon brush and match the 45t of this motor....
http://hpiracing.world/en/part/1065
do yu think that motor hpi will require fet upgrade....
if so then i can run pn racing motor like 32 turn....
Old 2016.05.07, 06:28 PM   #4
jcstuezday
jcstuezday's Avatar
i bought a 50 turn pn....
should better than a 45 turn modified hpi with alloy motor mount....
i have carbon fiber mount....
Old 2016.05.07, 10:13 PM   #5
Actually the stock micro rs4 motors (part #1060) are 180 and not 130 motors. I believe that the number pertains to the axle length (180mm vs. 130mm).
Part #105506 looks just like the graupner 300 if I remember, they used to call them big block motors.
The popularity of the hpi micro rs4 was hugely based on the ability to use 1/10 scale electronics. So using these motors wouldn't pose too much of a problem if you're using an esc for 1/10 scale.
Old 2016.05.12, 02:16 PM   #6
jcstuezday
jcstuezday's Avatar
ok....
I have had several motor....
Team Orion Big Block.... HPI 45T Modified.... A Brushles.... GPM Race High Torque 180.... Atomic Mod Nagasaki.... Performance Xmods $100 130....
STOCK CLASS talk and race reports. Zrc Miscellaneous Discussion 39 2014.11.25 09:10 PM
controller for box stock racing - kt18? y or n herman Miscellaneous Discussion 8 2011.08.12 02:21 PM
MHS is Hosting a PN Racing Mini-Z World Cup 2009 ruf993 Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 133 2009.07.27 09:38 PM
PM Racing Fet stock motor question 46u Motor Tech 6 2006.05.20 12:16 AM
IDEA! a way to turn a stock motor into a pn speedy equal ridealot100 Mini-Z Science 32 2004.07.28 07:01 AM
