Old 2019.03.02, 09:25 AM   #1
GIHOSU
Unregistered Abuser
GIHOSU's Avatar
Rules: 70 Comp
Dimensions:
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Chassis:
Open, 86-102mm wheelbase
Electronics:
Open, blinky mode operation (no advanced timing)
Motor:
Brushed 70t 130 or 130 sized 3500kv brushless motor
Gear limit:
3.6 final drive ratio (14/51, 12/44)
Battery:
4xAAA NiMh Batteries
Body:
Mini-Z compatible purpose built hard body (Kyosho, TRP, Jomurema, Iwaver, GL...)
Lexan window permitted. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally. Wheel wells may be altered for tire clearance but the body must cover the tire viewed from above. Headlight buckets may be omitted but lens must be in place (or covered by decal). Taillights may be removed. The rear bumper may be cut but no higher than 18mm from the chassis bottom . Holes are legal in the remaining fascia. Small body parts may be omitted. Front splitters and body sides may be trimmed for track clearance.
Wing:
All wings original to the body are legal. Aftermarket or non original wings must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX) or past widest point of body. This includes all parts of wing (side dams, etc...).
Performance option part:
Open
Wheels:
Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires:
Rubber tire of any company, no silicone or foam
MURDERTOWN Racing
GIHOSU is offline   Reply With Quote
2011 Stock Class Motor Rules pedrocamp High Speed Hobbies, NC 7 2011.02.23 06:55 PM
Mini-ZRacer.com Ann Arbor Mini-Z Dojo 2010 Racing Series Rules and Regulations mini-z Mini-ZRacer.com Mini-Z Dojo, Ann Arbor MI 3 2010.02.19 11:34 AM
Stock Class Rules Discussion AtlRC Atlanta Mini Scale Racing 5 2008.11.28 11:46 AM
2007/2008 Winter Season Schedule, Rules, and Prizes AtlRC Atlanta Mini Scale Racing 0 2007.11.11 12:46 AM
DISCUSS! Mini-Z / Scale 1:27 Proposed rules and regulations Kagan Events 29 2003.09.24 08:05 PM
