arch, i was looking around to find all the stuff that GPM make for the F1 and i found the site that i guess companies are supposed to order from. I counted the amount fo stuff available for the F1 and i counted 74 different things. However there are 10 different tie-rods, half are carbon fiber and the other half are alloy (each with anywhere from 2degrees toe-in to 2 degrees toe-out. But still thats a lot of items...so heres the list (from
www.gpmracing.com.hk)
DMZ007T DELRIN+ALLOY MOTOR GEAR-7T
DMZ008T DELRIN+ALLOY MOTOR GEAR-8T
DMZ009T DELRIN+ALLOY MOTOR GEAR-9T
DMZF1021 DELRIN FRONT KNUCKLE ARM (0DEG)-1PR
DMZF1021A DELRIN FRONT KNUCKLE ARM(1DEG)-1PR
DMZF1021B DELRIN FRONT KNUCKLE ARM(2DEG)-1PR
DMZF1021C DELRIN FRONT KNUCKLE ARM(3DEG)-1PR
DMZF1100 DELRIN BALL DIFF ASSEMBLY+SHAFT SET-1/16"BALL
DMZF1100A DELRIN BALL DIFF ASSEMBLY+SHAFT SET-1/8"BALL
MZF1TS TITANIUM SHAFT - FOR F1 BALL DIFF-1PC
DMZF1250 SPRING DAMPER+S/SPRING+DELRIN MOUNT-1PC
FMZF1510 FIBER+ALLOY REAR SUS PLATE SET(1MM)
GMZF1510 GRAPHITE+ALLOY REAR SUSPENSION PLATE SET(1MM)
GMZF1049/0 GRAPHITE STEERING PLATE (0DEG TOE-IN)
GMZF1049/1 GRAPHITE STEERING PLATE (1DEG TOE-IN)
GMZF1049/2 GRAPHITE STEERING PLATE (2DEG TOE-IN)
GMZF1049/T1 GRAPHITE STEERING PLATE (1DEG TOE-OUT)
GMZF1049/T2 GRAPHITE STEERING PLATE (2DEG TOE-OUT)
GMZF1208B GRAHITE LOWER BUMPER PLATE(FOR BENZ)
GMZF1208H GRAPHITE LOWER BUMPER PLATE(FOR HONDA)
GMZF1333 GRAPHITE+ALLOY WING FOR F1 (SINGLE DECK)
GMZF1333B GRAPHITE+ALLOY WING FOR F1 (DOUBLE DECK)
MZ002 ALLOY 2MM LOCK NUT SET -5PCS
MZ002L ALLOY 2MM FLANGED LOCK NUTS SET -4PCS
WL002 ALLOY WRENCH FOR SETTING 2MM LOCK NUTS
WL002L ALLOY LONG WRENCH FOR SETTING 2MM LOCK NUTS
MZF1021 ALLOY FRONT KNUCKLE ARM (0DEG)-1PR
MZF1021A ALLOY FRONT KNUCKLE ARM (1DEG)-1PR
MZF1021B ALLOY FRONT KNUCKLE ARM (2DEG)-1PR
MZF1021C ALLOY FRONT KNUCKLE ARM (3DEG)-1PR
MZF1021T TITANIUM STEERING SHAFT-1PR
MZF1030 ALLOY REAR STAB/LEVERS
MZF1031 ALLOY REAR HEAR SINK PLATE FOR MOTOR
MZF1031A ALLOY REAR HEAT SINK PLATE F/MOTOR -8FINS
MZF1032 ALLOY CENTRE GEAR BOX 2PCS SET FOR 6T
MZ040 SPEED+TORQUE MOTOR
MZF1049/0 ALLOY STEERING PLATE (0DEG TOE-IN)
MZF1049/1 ALLOY STEERING PLATE (1DEG TOE-IN)
MZF1049/2 ALLOY STEERING PLATE (2DEG TOE-IN)
MZF1049/T1 ALLOY STEERING PLATE (1DEG TOE-OUT)
MZF1049/T2 ALLOY STEERING PLATE (2DEG TOE-OUT)
MZ621T ALLOY FIRST SERVO GEAR
MZ622T ALLOY SECOND SERVO GEAR
MZ623T ALLOY THIRD SERVO GEAR
MZF1FR45SP FRONT+REAR SPRING (L7.5/10.5MM
MZF1F4SP FRONT SPRING (L7. 5MM X CORD 0. 4MM)1PR
MZF1F5SP FRONT SPRING (L7. 5MM X CORD 0. 5MM)1PR
MZF1R4SP FRONT SPRING (L.10.5MM X CORDO .4MM)1PR
MZF1R5SP FRONT SPRING (L.10.5MM X CORDO .5MM)1PR
MZF1250 SPRING DAMPER+SPARE SPRING
MZF1889 FRONT+REAR RUBBER RAD TIRE-2PR
MZF1889F FRONT RUBBER RAD TIRE -1PR
MZF1889R REAR RUBBER RAD TIRE -1PR
MZF112FR ALLOY FRONT+REAR WHEEL (FLAT 12P)-2PR
MZF112F ALLOY FRONT WHEEL (FLAT 12P)-1PR
MZF112R ALLOY REAR WHEEL (FLAT 12P)-1PR
MZF112FP ALLOY FRONT WHEEL (FLAT 12P)+R/TIRE-1PR
MZF112RP ALLOY REAR WHEEL (FLAT 12P)+R/TIRE -1PR
MZF186FR ALLOY FRONT+REAR WHEEL (FLAT 8H)-2PR
MZF186F ALLOY FRONT WHEEL (FLAT 8H)-1PR
MZF186R ALLOY REAR WHEEL (FLAT 8H)-1PR
MZF186FP ALLOY FRONT WHEEL (FLAT 8H)+R/TIRE-1PR
MZF190FR ALLOY FRONT/REAR WHEEL (FLAT VELOCITY)-2PR
MZF190F ALLOY FRONT WHEEL (FLAT VELOCITY)-1PR
MZF190R ALLOY REAR WHEEL (FLAT VELOCITY)-1PR
MZF190FP ALLOY FRONT WHEEL(FLAT VELOCITY)+R/TIRE-1PR
MZF190RP ALLOY REAR WHEEL(FLAT VELOCITY)+R/TIRE-1PR
DMZF190880 DELRIN FRONT+REAR MOUNTED FOAM TIRE-2PR
DMZF190F80 DELRIN FRONT MOUNTED FOAM TIRE-1PR
DMZF190R80 DELRIN REAR MOUNTED FOAM TIRE-1PR
DMZF190F80S DELRIN FRONT MOUNTED SOFT FOAM TIRE-1PR
DMZF190R80S DELRIN REAR MOUNTED SOFT FOAM TIRE -PR
DMZF190F80H DELRIN FRONT MOUNTED HARD FOAM TIRE-1PR
DMZF190R80H DELRIN REAR MOUNTED HARD FOAM TIRE-1PR
DMZF190FI DELRIN FRONT WHEEL+INSERT(VELOCITY)-1PR
DMZF190RI DELRIN REAR WHEEL+INSERT(VELOCITY)-1PR
DMZF191880 DELRIN FRT+REAR MOUNTED FOAM TIRE-2PR
