Go Back   Mini-ZRacer.com Forums > General Discussion > Transmitters, Receivers and Crystals
Old 2018.03.12, 01:08 AM   #1
sangyue
New Product Information- Kyosho MHS ASF Compatible 2.4GHz Full Range RF TX Module
Kyosho MHS/ASF Compatible 2.4GHz Full Range RF TX Module
Description:
This 2.4G RF TX module support both the well-known Kyosho ASF system and Kyosho's innovative MHS (Mini-Z
Hybrid Spread) system. This module is designed to convert any transmitters with PPM output to have the ability to
connect Kyosho ASF/MHS micro racing cars. This is also a full range module allows you could control your ‘Mini-z’
cars in 150M range in open space.
Features:
1. Kyosho 2.4GHz ASF/MHS Selectable on board
2. High performance CPU enhance precision control feeling
3. 4 channel support
4. Micro size (30x20x5mm)
5. Ideal for converting any transmitter with PPM output
6. Operating Voltage 3.7V – 9.6V:
7. Weight: 10g
Package Included:
1 x 2.4G ASF/MHS RF TX module
1 x 1.5mm 6P JST plug with cable
1 x 2.4G Antenna
1 x 2.4G 3DBI Brass Tube Antenna
1 x 2.4G 3DBI Module Antenna
BIND:
Press the “BIND” Button and power on the RF module, it will enter BIND mode
Notice:
Make sure antenna is connected before power on, power on without antenna connected may damage the PA unit.
Wire Connection:
sangyue is offline   Reply With Quote
Old 2018.03.12, 06:36 AM   #2
Rretty interesting, thanks for sharing. Who makes this and where can it be found?
Old 2018.03.12, 08:22 AM   #3
This could be of interest to a lot of people. Especially those holding older KO and Futaba transmitters without a usable module.
Am curious myself about the manufacturer. The photo's have a Das Micro look to them.
Old 2018.03.12, 10:26 AM   #4
I thought so as well however did not see a listing for this on the typical site(s)
Old 2018.03.12, 11:16 AM   #5
TeeSquared
Redline
This is very exciting!!! If this proves reliable it will be an excellent alternative/upgrade to the RF901 module.
Old 2018.03.12, 12:10 PM   #6
Considering the obvious source it is probably a knock off of a pirated clone.
Old 2018.03.12, 12:28 PM   #7
At this point, what are the options left to the market when many if not most of the 'module' style receivers are long since discontinued. Doesn't bother me in the least given a used module, as rare as they are, are still very expensive and still no guarantee of operation. Clone=no warranty support, discontinued/used=no warranty support.
Old 2018.03.12, 04:29 PM   #8
Now we just need somebody with the talent to do a pin out so you can mount it in the base of a 4PK or any of the standard KO radios and clones. since it isn't an encased module.
Old 2018.03.12, 07:23 PM   #9
Interesting. I have one module that I believe might be on its way out...
Old 2018.03.13, 01:01 AM   #10
sangyue
But there is no such MHS/ASF module product from Ko Propo or Kyosho, how could you clone a not existing product?
Old 2018.03.13, 01:03 AM   #11
sangyue
It will be available on Banggood soon. PN racing will also have this product online...
Old 2018.03.13, 02:11 AM   #12
sangyue
Preorder link from Banggood...
https://www banggood com/DasMikro-Ky...r_warehouse=CN
Old 2018.03.13, 07:00 AM   #13
Well, technically is not the EX-6 and MHS/ASF system that would have a board within? While not being in a traditional module form factor, the transmitter control module would certainly have a similar electronic component I would think.
regardless, there is a market for ASF/MHS support for older plugin in module radio platforms that is simply not served by the respective manufacturer any longer. With suitable compatible parts becoming rather rare and costly to location and procure, this would seem to serve as a god send to many seeking to keep their favored transmitters.
Now, if we could just get one module that would run ASF, FHS, MHS, FHSS.... One module to rule them all!
Old 2018.03.13, 07:02 AM   #14
Interesting as well to see NA retailer pick up Banggood products.
Old 2018.03.13, 07:54 AM   #15
Curious to see how much higher the North American retailer sets the price as well as what type of warranty consideration they will provide.
Kyosho Mini-Z F1 MF-010 SP Limited Edition ASF 2.4GHz Tx-Less 30510SP In Stock! mini-z Mini-ZRacer.com Announcements 0 2009.08.19 03:01 AM
FS: Kyosho Perfex KT18 2.4Ghz ASF Controller - Barely Used limbohz Mini-Z Marketplace 1 2008.07.31 10:25 AM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF In Stock! mini-z Mini-ZRacer.com Announcements 0 2008.02.29 02:20 PM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order mini-z Mini-ZRacer.com Announcements 0 2008.02.18 03:53 PM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 05:02 PM
