Hey guys - put my PN F1 motor mount and noticed (keep in mind I'm new to the MF series) that the FRP side plates seem to want to pull the motor motor mount down and away such that the damper post nub on the PN mount catches the plastic loop right behind the batt terminal attachments? I went to put the rear shock on and that doesn't seem like it will do anything since it's trying to "droop" in the rear of the car.
Maybe the weight of the batteries will balance it a little more and excuse my noonbness on this chassis but just wondering if this is normal ?
Again, no motor, no batteries yet ... maybe that has something to do with it ----- I have to use the lowest axel position with the bearing carriers on the PN F1 mount to get it level like this
This is the "loop"
I have the Shapeworks PN top shock adapter coming which I plan to use. Also have the DD from Kyosho --- whats the best to use with the PN mount?
Thanks Cowboy - so do people run these with out rear Springs?
Also, I noticed on the kyosho to shock that the instructions show the mf010 and I tried to use the metal bride you see in the second picture above - it's from the picking inner tube shock set . As I mentioned, I have the shape ways mount for the pn top shock on order so I'm just trying this in the meantime. is there supposed to be a reverse rake of the shock down to the pn mount or do I shim to make it parallel with the chassis?
I guess I'll put motor in/batteries in to get it to actual weight before doing this
I have not tried to put the shell on yet so I don't know about clearance in there yet!
I was planning on a 70t pn to start or is a 50t pn a better choice ?
Thanks again for the F1 expertise - new chassis for me
Some people find the springs accentuate any chassis tweak issues. I run without them and there are a few others I know who delete them.
Try to get the Kyosho shock as level as you can.
The 50T might be a bit much to start with F1 because being a bigger heavier chassis it tends to roll a lot more so it takes a bit to adjust to braking points.
Do yourself a huge favor and get a front wing protector from "UsefulIdiotDesigns" on the Shapeways site. Best idea for a protector that stops the wing from getting stuck under the rails.
Ok --- I actually ordered the F1 wing from Shapeways but just received today and see that I CANT use the Kyosho IC tag (we use the IC Lap counter system)
No way to mod it I guess?
I'm not familiar with the IC tag and its fitment so I couldn't say.
