Old 2018.12.23, 03:21 PM   #1
sake138
Pn racing spektrum
So I got it installed but How do you get the brakes to work?
sake138 is offline   Reply With Quote
Old 2018.12.23, 04:08 PM   #2
Check your throttle trim. Also ensure that the polarity of the motor is correct. If you need to double tap throttle after hitting the brakes, then the polarity of the motor is backwards.
Old 2018.12.23, 04:23 PM   #3
sake138
I pull back and have throttle forward have to push forward twice to get in reverse. When I push forward the car just keeps rolling
Old 2018.12.23, 04:36 PM   #4
Your use of forward is confusing me. When you pull throttle, the car moves in the correct direction. When you push throttle, does it not brake? And pushing twice gives you reverse? So, you have proper functionality of reverse, but no brake effect? If this is the case, you should contact PN and see if there is a setting adjustablie via ICS that is not set correctly or for warranty replacement.
Try different throttle trim settings, and ensure that the brake hipoint on the transmitter is as at 100.
Old 2018.12.23, 04:38 PM   #5
sake138
Sorry yes controls are correct. When I apply the brake it just continues to roll fast.
Old 2018.12.23, 08:39 PM   #6
If you can engage reverse, I would think a software issue, not a hardware issue..
Old 2018.12.23, 08:54 PM   #7
sake138
I was thinking the same I just wondering if others had this, and if it can be changed via ics. I don’t have one but will order one
Old 2018.12.23, 09:46 PM   #8
Before ordering one, contact PN about the issue. He should know more about resolutions than we do here, and may want to replace it to ensure you have a working product and troubleshoot the anomaly himself.
Old 2018.12.23, 09:56 PM   #9
sake138
Spoke to someone from Kenon hobby, he said to adjust the brake trim in my radio. I can’t find that in the Dx5pro
Old 2018.12.23, 10:36 PM   #10
I wish I could help, but I've only used spektrum on my KO Helios via module...
Old 2018.12.23, 10:38 PM   #11
sake138
Well I turned the brake rate to 100% slows down a little now. Next option might be doing it via ics
Old 2018.12.26, 04:06 PM   #12
art4242
In the PN ICS app, there is a brake power option which you can adjust (see attached screenshot). I forgot what the default was set to out of the box.
art4242 is offline   Reply With Quote
Old 2018.12.26, 09:11 PM   #13
sake138
Thank you! Now I’ll place an order lol
Old 2018.12.27, 07:38 AM   #14
sake138
Where do I find the link for the program for the computer?
Old 2018.12.27, 07:44 AM   #15
I would think that PN would be a good place to start the search.
FS: MR-03 Parts arch2b Mini-Z Marketplace 2 2011.07.04 02:13 PM
FS: PN Racing MR-02 2.4ghz + KT-18 RTR ekim628 Mini-Z Marketplace 12 2008.09.27 10:29 PM
Inside Line Racing Anniversary Race Z_408 Events 3 2008.09.15 03:15 PM
Intercontinental Racing using 3D RC Racing Blackno3 Red Hill Games 3D RC Racing 0 2008.02.26 06:44 PM
FS/T: KYOSHO / PN RACING PARTS MR01/F1/Overland kryten Mini-Z Marketplace 4 2008.02.19 05:09 PM
