I'm busy updating the list for several hours now but I do'nt know what happens if anybody else gets in and modifies the spreadsheet during my edit...
I kept a XLS backup just in case...
btw I'm editing it as "anonymous". How can I edit with my login?
Don't worry nothing happens, I've just gone in and Highlighted the "KYOSHO" row on the top, to prove you that Send me your email, and I will send you a invite, i guess after that your edits will be displayed w/ your name.
I also done some cleaning up. Please correct me if I'm wrong but I noticed that AWD offsets were the same as MR-01/015, so I grouped them together. Also MR-02 offsets were grouped with MR-03 ones.
can you have the offsets automatically populate based on basic conversion units?
mr-01/mr-015 to mr-02 is generally a fixed conversion unit.
mr-03n=mr-01/015
mr-03w=mr-02
ma-010/015 to mr-02 is generally a fixed conversion unit.
this way one would only need to know the offset for the release and it would automatically populate the others based on fixed conversion units. this is something that could be wipped up in excel in short order by someone with spreadsheet experience.
mr-03 offset can be divided into mr-03n and mr-03w. mr-03n=mr-01/015, mr-03w=mr-02
MR01/MR015/MR03N to MR02/MR03W:
Rear : same
Front : + 2.5mm to each wheel
MR01/MR015/MR03N to MA010:
Same rear and front
LM to MR02/MR03W:
Rear : + 2mm offset to MR02 wheels.
Front : stays the same.
Height wise lower MR02 or MR03 chassis by 1mm in the back, and .75mm in front.
Of course, wheels for AWD are different from RWD wheels, because the structure of the axle itself, but you know that.
Arch2b, don't tell me you're impressed
I'm absolutely sure you had set up a spreadsheet way more complete than what we have here (poke poke)
Actually I was hoping a lot from your experience here
the years have not been kind to my memory recall of misc. mini-z factoids
i've tried many times to get something of this nature built over the years and i'm sure i've made many lists but i just don't remember where they went i'd have to do some dedicated searching through the forums here. i've already searched through my records at home with no luck. i've lots a couple hard drives over the last 10 years so it wouldn't surprise me if i lost that work.
i do know i started a thread on the guide sheets that came with autoscales that has a lot of useful information. i recall searching for it in one of the 'rare' autoscale threads.
Arch2b, do you happen to know what these fixed conv. units are ? I can try to hack that into the tables.
The database has been updated w/ the formulas to calculate the offsets. All one needs to do is enter the Front Offset for the MR-01 Column and the Rear Offset for the ALL Column. It will calculate for MR-02/03W and MR-02LM. The Wheels Width must also be entered
When inserting a new line just copy the formula from the rows above.
Perhaps we could add the standard wheel offset conversion table on the reference page as well. It may be handy to note that +3.5mm narrow = 0mm wide. Or +2.5mm narrow =-1mm wide. Many ask if wide wheels can be substituted for narrow.
arch2b, I had already added the table on the Refs page and I will include this extra info you just provided as well. Again, the doc is open and you can go and edit it yourself I hope we can get you in this project!
