2003.10.02, 01:25 PM
Mini-Z Pro
Parts needed to upgrade to mr02 chasiss
Anyone know all the nessery parts needed to do the convertion. I have a new mini-z and want to fit all the parts into a Mr02 chasis.I would like to buy the least amount of parts possible to keep the costs low. Im a newbie to this, is it hard transfering every thing to the new chasis ?
I think these are all the part i really need, read form donout`s post.
Kyosho (#MZF201C) Skeleton Chassis Set (Clear) For MR02
Kyosho (#MZ203) Front Sus. Parts Set For MR02
Kyosho (#MZ205) Servo Saver Assembly For MR02
Kyosho (#MZF202BL) Color Screw Set For MR-02 -Blue
Do i really need the front suspension part, Servo saver and color screw set, Ant i use mr01 screw set that came with my car ?
Thanks for your help.
2003.10.02, 01:47 PM
see your other post....no need to repost if you already asked in another thread, unless your trying to create a defininative list for others to use...
2003.10.03, 11:06 AM
Mini-Z Pro
Sorry about that Arch2b
Sorry about posting it twice, thats what i wanted to do, i wanted to creat a post were everyone can see, if it easy to upgrade and what parts are needed to uprgade to mr02 chasis.
2003.10.03, 11:41 AM
2003.10.06, 09:47 AM
Mini-Z Pro
Order placed !
Yesterday I order my parts, form hong Kong, i would of preffered buying it from miniz, Wich i trust more do to the fact that it in united states.
These are the part that i orderd :
Kyosho (#MZF201C) Skeleton Chassis Set (clear Blue) For MR02
Grand total was $31.33
This price includes the shiping and i paid a little more for prioritysomthing. They claim that it should arrive from 7-14 days.
This is the first time i buy somthing in the internet
Any of you have expirience with T****** ****** ? BAout their seirvice?
Ill post how the conversion goes with photos when the parts arrive.
I took apart my mr01 to see how the pcb was installed. and i saw that it was solderd i think, To the battery trays, form each side. Once one gets it out, is it easy soldering back together on the Mr02 body ?
thanks fro oyour help people !
Cant wait for the to arrive.
2003.10.06, 10:37 AM
the pcb is not soldered to the chassis. having installed a clear chassis on my racer and n=both overland's a can tell you it's the same setup. there is 1 screw for the plate that holds the on/off switch in place and 2 screws for the power ring terminals, 1 red wire, 1 black wire. these scew onto mounts along with the wires from the battery compartment. this is where the overland and racer's differ. the pcb wires scre into similar mount directly under the motor hookup location. the overland's are in a seperate mount close to the on/off switch. i only opened up my enzo once so i do not recal where it is, but i can assure you there is no soldering involved.
2003.10.06, 11:01 AM
Mini -Z Mutilator
I did read in another post that the tabs for the power on the MR01 are too big for the MR02. you will need to solder the bigger tabs off and smaller ones (size of one of the motor or antenna connections) That was all the modification noted. Sorry that I don't remember what thread it was in but I read it this weekend.
2003.10.06, 12:39 PM
Mini-Z Pro
Thanks , I opened y miniz, got the pcb out totally, the other time i did it i didnot get the pcb out because i thought it was going to be solderd on to some part of the chassis. Arch2b is right, nothing was solderd together . Good
I think i know what ar you taking about PaulAngelo, i think i know what the tabs are, I did a picture of it to see if you guys can verify it is what i think !
here ya go .
2003.10.06, 12:42 PM
Mini-Z Pro
O and anther thing,
The White servo box, does it fit entirely into mro2 body or do ihave to take that apart ?
Excuse my spelling errors, English is not my first language.
2003.10.06, 12:49 PM
Mini -Z Mutilator
Those are the tabs I am talking about. They are too big for the inside of the MR02 chassis. The white servo box would have to be taken apart. The Motor and Pot would be put in the MR02's version of the servo box with the servo saver pieces.
2003.10.06, 12:55 PM
oops paul... beat me too it
considering the 02 uses an entirely different servo setup, i would assume you remove the pot and servo motor from the white servo pod (01) to be placed in the 02 with the new parts. this is a best guess as i did not open the servo area of my 02 yet. now if you wanted to know anything about the overlands servo...i'm an expert as i've resoldered every connection atleast once.
btw, what is your first language? your english is fine.
2003.10.06, 09:18 PM
Re: Order placed !
[i]These are the part that i orderd :
You're going to need:
Kyosho (#MZ202) Small Parts for Chassis
which includes the cover for the PCB and some small plastic parts (hence the name ) such as bulkheads that hold the servo gear shafts.
2003.10.07, 10:37 AM
Mini-Z Pro
What , O noo, ? I thought it came included in the clear chasis set, Aaaa man, i hope my hobby shop has at least those parts in. O well no prob. Hey donut, Are you done with you convertion ? How did it come out ? Do you know of a place were i can download the exploded view diagram of the mr02 ?
Thanks for your help Donut
2003.10.07, 03:07 PM
rc mart usually has the manual's for download (they don't ship them in the box)
2003.10.07, 03:14 PM
Mini-Z Pro
Cool Thanks
Cool thanks, arch2b, Ill take a look at thier site !
