Go Back   Mini-ZRacer.com Forums > Manufacturers > RCP Tracks > RCP Support Forum
Old 2006.05.04, 12:42 PM   #1
builthatch
yes, it's a boxer
builthatch's Avatar
i searched...i have a total area Q about mini96 + exp pack
experts- i am picking up a mini96 and an mini96 expansion pack-
i have about 1.5 cars worth of space in a 2 car garage width wide and length wise about 1.5 car lengths.
i see the mini96 is 7'9" X 11'8"...so, how much total area will it be with the expansion pack, if you have to make it a compacted rectangle like RCP shows on the site in the 96 expansion pack description???
Thanks!
Reflex Racing :thumbup:
Old 2006.05.04, 04:24 PM   #2
Spoon
DCGTG FET Guy
Spoon's Avatar
Thanks!
I think you are looking at a minimum of 12 ft. by 14 ft if you want to use all of your space. I think Bolter9 has some layouts that use the Mini-96 + expansion in a similar space. Look for his gallery.
I am trying some layouts now, I'll report back.
Old 2006.05.04, 04:31 PM   #3
builthatch
yes, it's a boxer
builthatch's Avatar
ok, i c, yeah i calculated 12' x 16' if it was a compact rectangle setup like the one pictured on the rcp site in the expansion section.
hmm, ill peep those galleries....i can't wait to get a track! relieves so many headaches and allows me to use my modded car now at home-
Old 2006.05.04, 04:52 PM   #4
bolter9
How're YOU doin?
bolter9's Avatar
Send a message via Yahoo to bolter9
Way to go- you're going to love the track!
If I set mine up in half of my 2 car garage, it runs about 8'x18'- that's mini tile with expansion (using all tiles..general oval shape layout).
I've got about 6 extra turns that I purchased from RCP, so now days I'm setting up in more like '14x'20.
Those are real ball park figures though- it really depends on what shape the space is that you have (rectangle or square), and the actual configuration of the track.
Either way, you're going to have a blast!
Havin' a good one!
My Gallery
bolter9 is offline   Reply With Quote
Old 2006.05.04, 04:56 PM   #5
Spoon
DCGTG FET Guy
Spoon's Avatar
I think there's too many tiles in that layout. if ti's 12x17 tiles that's 204 tiles.
A mini 96 should be 96+60= 156 tiles. Since each tile is about a square foot you are looking at 156 sq feet or 12x13.
I haven't actually set up a Mini + exp. so I am not sure ou can make it as compact as you want. But if you have 150-200 sq feet available it seems like it would be worth getting the expansion.
Old 2006.05.04, 05:26 PM   #6
machine
learning the hard way
machine's Avatar
I got my expansion in the other day and love it! The straight can now pretty much be a drag race of 3 cars.
[Western Canada's Mini Rc Home[/URL]
machine is offline   Reply With Quote
Old 2006.05.04, 06:38 PM   #7
bolter9
How're YOU doin?
bolter9's Avatar
the expansion is the way to go for setting up a little variety. I run the straights wide (3 tiles), a couple high speed corners wide, and keep all the chicanes and hairpins at 2 tiles- it's a great way to practice your line for when you're running tight corners on a full-sized RCP.
Havin' a good one!
My Gallery
Old 2006.05.04, 10:03 PM   #8
builthatch
yes, it's a boxer
builthatch's Avatar
good info, thanks y'all. i can't wait. finally, FINALLY i can use my mini-z w/o having to drive 2 hours. and the worst part is i was using it before in my garage, but now that its fetted/z2'd...it's totally impossible to use in the garage w/o turning the throttle EPA down to like...30%...which makes it only a hair faster than it was unfetted w/ the o5 BB, so i want to finally be able to take advantage of the new found power.
Old 2006.05.15, 09:06 PM   #9
builthatch
yes, it's a boxer
builthatch's Avatar
i ordered my mini 96 today. i am excited; i only got the mini 96 w/o expansion packs because i want to get used to the little track before i start blowing more cash on it.
Old 2006.05.15, 09:37 PM   #10
bolter9
How're YOU doin?
bolter9's Avatar
congratulations! you're going to love it!
I bet you'll have the expansion pack in a week though
Havin' a good one!
My Gallery
Old 2006.05.15, 10:54 PM   #11
congrats! it will make you a much better driver, then you get to expand with the expansion pack if needed all the top drivers in dc have a mini-96 at home
Old 2006.05.15, 11:05 PM   #12
builthatch
yes, it's a boxer
builthatch's Avatar
thanks! and most importantly, i can actually use my car now!
Old 2006.05.22, 04:10 PM   #13
builthatch
yes, it's a boxer
builthatch's Avatar
i got the track this afternoon. Assembly of course was a snap and i love it! i promptly ordered the expansion pack as i realized i will definately need it if i plan on hosting more cars...
i realized after a couple laps that the PN tire tape i've had sitting in my toolbox is a MUST when it comes to 8 degree tires and high-grip side RCP.
BTW, what side do most of you run? rough or smooth?
Old 2006.05.26, 02:39 PM   #14
mini-z
Administrator
mini-z's Avatar
Congrats builthatch! Just about everyone runs the grip side, and yes, that tape soon proves its worthiness, doesn't it?!
Old 2006.05.27, 11:46 AM   #15
HammerZ
Master of Thrash
HammerZ's Avatar
I guess my track would look just like that. All I know now is mine left Texarkana on it's way here.
NiMH Battery Info G-Class Parts and Hop-ups 5 2004.09.09 11:29 AM
