Old 2004.08.06, 05:14 PM   #1
ahalo
Stripped screw
Well today i broke the stock H-Plate on my NSX. When i was replacing it one of the screws that connects the H-plate to the motor mount stripped completely! I think the only thing i can do is either buy a new alloy motor mount or replace it with another stock one. Would anyone happen to have a sotck motor mount for the RM chassis lying around? And would be willing to sell it to me? Thanks!
ahalo is offline   Reply With Quote
Old 2004.08.06, 05:24 PM   #2
TNB
Pet Human
TNB's Avatar
Did you try Dremeling or notching the screw and using a common/flat screw driver to remove the stripped screw?
Gallery TNB
Old 2004.08.06, 05:33 PM   #3
ahalo
no but i will try that, once my dremel gets here.....
Old 2004.08.06, 05:56 PM   #4
Ninja
Mechanic
Ninja's Avatar
i done this once and it worked great with the small dremmel cutting disc
Real Racers Do It Sideways.
Old 2004.08.06, 10:19 PM   #5
ChiefGreenLeaf
Registered Abuzer
ChiefGreenLeaf's Avatar
Put a soldering iron on the screw head for a few soconds.It'll loosen up the threads a bit and make it a little easier to get it out when you can grab it with something.If you can break out the H-plate from around the screw just heat it up and grab it with some needlenose pliers.
ChiefGreenLeaf is offline   Reply With Quote
New chassis screw boss question andreophile Beginner Questions 16 2008.04.28 08:39 PM
I accidently stripped a screw Jormar23 Mini-Z Overland MV-01 9 2004.04.28 11:13 PM
i stripped a screw bmx_r87 Miscellaneous Discussion 5 2003.07.19 02:03 AM
Stripped screw holes of chassis? Big-Z Setups 6 2003.02.03 01:58 AM
repairing stripped screw holes Wedginator Mini-Z Science 20 2002.05.27 07:53 PM
