I can say that the Kyosho diff uses standard size balls... I replaced them myself thinkin they might be out of round. That may or may not be important. I would think that more balls is better since the load would be distributed along more surface area.
I'm also not a huge kyosho diff fan because I had to add more shim to my motor, but I seem to be the only case of this.
I could only get a Kyosho ball-diff.
I am thrilled with it, best hop up yet for me..
As for the amount/size of the balls within the diff, this is one of those arguments from 1/10 scale racing days, although 1/10 scale ball-diffs are slightly different as it uses wafer springs and has recesses for the thrust balls in the pressure plates of the diff. A heavier duty ball-diff overall!
I personally came to the conclusion that it's six of one and half-a-dozen of the other. The same!
Kyosho use 5 or 6 thrust balls of a larger size. GPM use more for a smaller size. I think it works out the same.
The upside is that GPM have different sized spur gears, but I ask the questionas to whether anyone would use them?
Most tinkerers make adjustments on the pinion gear as it's simpler.
From 1/10 racing I know it can be hard to keep track of the various spur/pinion combinations that work best!
I think buy what suits ytou best, price, availability and backup.
One thing I do know, is that every little part of the Kyosho ball-diff can be purchased seperately. Can GPM's ball diff be ordered in parts?
Would anyone want to replace a diff if they only needed a solitary part for it? I wouldn't!
I use the spur gears alot actually If you have the stock motor mount, using the 40T spur will let you fit up to a 13T pinion, where if you leave the 42T on, you can only fit up to about a 10T.
The K ball diff has worked out nicely since I added a little (1/32 inch) of shim to it. Even raced and took 2nd, 1st, and 2nd in the amature league last thursday with it! I don't know why my diff was oversized but it seems to be fine now that I added the paper shim in.
