Old 2007.07.07, 06:02 PM   #1
Programmers
iTomCash
iWaver electronics with an MR02 servo...
Basically: What makes the iWaver servo twitch? The servo or the electronics? For a more in depth explanation, read on.
I recently had an iWaver with a 2x2 4562 stack and the servo twitched a lot and I sold it - the whole thing.
Then I burnt out a MR02 board by accident and I am left with the servo... I have just been browsing the net and I have found a iWaver board with 4562's on. Will this still 'cause the servo to twitch, or will it be fine as it's a Kyosho servo.
I don't want to fork out $80 for MR02 electronics when iWaver electronics are $21.50 with 4562's, brand new...
All help would be greatly appreciated.
Old 2007.07.08, 05:57 AM   #2
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
i would imagine it was the pot you had tom as i have 2 iw's and 2 iw boards in other stuff,none of them twitch
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2007.07.08, 09:09 AM   #3
Programmers
iTomCash
Excellent. So I should not worry about getting the iWaver electronics and using them with a kyosho servo?
Old 2007.07.08, 10:39 AM   #4
imxlr8ed
imxlr8ed's Avatar
I will always recommend trying to find Kyosho boards, you could always try to find a used MR01 or an MR02 for the same price you'll pay for a new ESC.
I have an MR01 board in my AWD Mod car... works perfect! (and no double-tap reverse) Shop around... I've seen used RTRs sell on some sites for as low as $50. Just try to build value into it, even if you don't use the chassis or the body, you could always sell them off to get back some of the purchase price.
As far as the difference between the Kyosho and Iwaver ESCs... I think the main difference is that the Kyosho ESC's servo power is controlled by fets and the Iwaver is done by a rectifier. I have seen members change potentiometers on the Iwaver boards to try to get the glitches out too, can't say it's a sure-fire fix.
Just listing possible avenues for you... good luck!
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
Old 2007.07.08, 03:36 PM   #5
Programmers
iTomCash
Thanks for that!
My MR-02 Project (Hot-Shoe-Blue) AaronM Mini-Z Racer MR-02 21 2005.10.15 10:16 AM
Iwaver Electronics TheGiftedOne iWaver 11 2005.06.08 08:19 PM
servo problem on mr02? Paradigma Mini-Z Racer MR-02 2 2004.01.25 05:00 PM
servo compare of MR02 and OL PAULANGELO Miscellaneous Discussion 3 2004.01.12 01:11 PM
servo convertion killer Mini-Z Science 21 2003.01.03 07:30 PM
