Old 2009.02.02, 08:46 AM   #1
rickyb
Front end
COULD SOMEONE EXPLAIN TO ME HOW THE FRONT END WITH THE "TORSION BAR" WORKS? WHAT DO THE DIFERNT H PLATES DO IN THE FRONT END. I UNDERSTAND THAT A SOFTER PLATE ALLOWS MORE FLEX. SO SAY YOU GO INTO A LEFT HAND CORNER, WITH THE "BAR" IN THERE AS THE CAR ROLLS OVER TO THE LEFT SIDE THIS BAR WILL THEN TRANSFER SOME FORCE ON THE RIGHT SPRING AS WELL THEREFORE COMPRESSING THAT SPRING ALSO. AM I RIGHT SO FAR? THIS WOULD THEN ALLOW THE FRONT END OF THE CAR TO DROP IN THE CORNERS, LOWERING THE CENTER OF GRAVITY? MAYBE????
STREET DEMONS
MR-02 MOD,STOCK
MR-01
MR-010 MOD
F1
XMOD EVO MOD
rickyb is offline   Reply With Quote
Old 2009.02.02, 02:55 PM   #2
ProfoxCG
Send a message via AIM to ProfoxCG
The S-bar, yes will compress the interior spring a bit this will allow the specific end of the mini-z to stay relatively flat (or with minimal body roll) enhancing traction on that specific end.
However there is something I am missing, I belive that a S-bar in the front of the mini-z for example, will stiffen the suspension up-front and yield more traction of the rear.. right? someone help me,
I have had great success in reducing traction roll in my Ma01 by using the ATM S-bar kit.
KO EX-1ur | MR02 Spec 0 | dNano Type 1
ProfoxCG is offline   Reply With Quote
Old 2009.02.02, 06:08 PM   #3
rickyb
plate
so what would a stiffer or softer h plate do to the front end?
i would think that stiffer would cause the the "inside spring" to compress more along with the "outside spring" causing the front of the cars c.o.g. to be lower, then resulting in less chassis roll, which would mean then; more traction to the front end with less traction roll?
STREET DEMONS
MR-02 MOD,STOCK
MR-01
MR-010 MOD
F1
XMOD EVO MOD
Project: Building a Race worthy X-mod Kel Mini RC 197 2011.12.21 08:22 PM
Hmmm.. Binding inthe front end. Need Help (pics) ryno Mini-Z Monster MM-01 6 2005.10.17 08:25 PM
That loose front end.. Digisane Mini-Z Science 1 2003.08.23 01:07 PM
Doubel dampers in the front! ultrawide Mini-Z Overland MV-01 8 2003.08.06 05:01 PM
Modena, Finally Drives Adult_driver Setups 10 2003.01.18 01:24 PM
