Old 2006.04.16, 05:27 AM   #1
Dusty Weasle
Here kitty, kitty, kitty
Dusty Weasle's Avatar
Minolta Toyota 88C
Iím having so much fun painting my McLaren body that I got it in my head to do a 1:24 conversion kit. Luckily there was a model kit swap meet here recently and I found numerous kits to choose from. It was tough to decide on just one, but I finally settled on this Hasegawa kit of the Minolta Toyota 88C for $17.
I wanted to do an LMP1 open-cab car, but aside from the staggering price of the only kit I found (around $120), the back end sits so low to the axle that I doubt itíd work even with an F1 chassis.
So here are some pictures of the early planning stages. The wheel base is a good bit longer as I expected. I forget the numbers now, but I think I can just use an RM T-Plate mounted on a different spot. If not Iíll just build an extension plate.
My plan was to use F1 wheels and tires which turn out to be very close to the scale tires, but then I discovered the F1 fronts only sit correctly on the longer F1 knuckles, so that idea is out. Iíll have to make do with the smaller MR wheels and 3mm offsets.
The thing I didnít see coming was the radiator intakes. They protrude pretty far inside the car, intersecting the outer battery compartment. Iíll have to do some careful measuring and cut them back, then use sheet styrene to close it back up.
As with my McLaren project, this will likely proceed very slowly. Busy, busy, busy, but Iíll post updates as they happen. BTW, Iím almost done with the Rainbow Studios McLaren seen in the other thread. Itís 12th coat of Gloss is drying right now.
www.Mini-AZ.com
www.Mini-AZ.com/ISRL.html
"Itís not about turning left, itís about not turning rightĒ.
Dusty Weasle is offline   Reply With Quote
Old 2006.04.16, 05:53 AM   #2
HaCo
02-Racer
HaCo's Avatar
You could use the Minolta decals on a VDS shell, would look perfect IMO
Old 2006.04.17, 03:24 AM   #3
that's going to become one sic mod... can't wait to see it...
Old 2006.04.21, 06:02 AM   #4
Dusty Weasle
Two Steps Forward, One Step Back
Proceeding along, I took lots of precise measurements and began cutting up styrene to build the custom side clipsÖ what a waste.
After I began I realized, for less money than I spent on styrene packs, I could just order VDS clips and glue spacers on them. These clips must reach 3/4Ē inside, with the wide back plate reaching a full inch.
Oh well, plug forward. Astonishingly, Hobby Bench didnít have the T-Stock to fit just exactly the size needed, so I got solid strips. With a couple hours of carving and filing the T-notches were made. The plates were glued together and the clips looked good.
But alas, the next day I fitted them again into the chassis to proudly show the wife my nightís work, and noticed that one clip angled up higher than the other. Doh.
Its tough to hand carve an even notch, much less its twin. So, Iím just going to order the precise and uniform VDS body clip set. Itíll be easier to just make even spacers for them. This fitting must be precise or the body will not sit level.
The cut-lines have been carefully measured and marked out on the radiator intakes. Next up they go under the saw so that the body will fit over the batteries.
www.Mini-AZ.com
Old 2006.04.21, 01:28 PM   #5
Fish
Fish's Avatar
Send a message via MSN to Fish
Can't wait for the results. Everything looks pretty good so far.
Guess you're set on the blue/white Minolta livery? And the side vents look to be functional now, drawing air into the battery area.
miniRC ca
Fish is offline   Reply With Quote
Old 2006.04.21, 02:42 PM   #6
ARN
so will the vds wheel offset work well for this?...what about that CP mr-02 cup car kit to extend the wheel base? anyway look cool!
ARN is offline   Reply With Quote
Old 2006.04.21, 10:50 PM   #7
hmm... wouldn't a mr015 chassis be a better fit? you would just have to have the right offset rims up front and rear...
Toyota Harrier Project. cola Mini-Z Overland MV-01 13 2006.04.23 01:26 PM
F1 For Sale: Panasonic Toyota TF102 francis_Z Miscellaneous Discussion 14 2004.06.22 08:07 AM
TOYOTA Truck fans Random Insanity Off-Topic 4 2004.01.06 09:50 AM
what's da matta with toyota? West.F1 Mini-Z F1 MF-010, MF-015 0 2002.09.26 03:08 PM
Home made Bumper bar for Toyota Altezza 280T models Slayer Beginner Questions 3 2002.02.05 07:50 PM
