Old 2002.05.30, 05:34 PM   #1
Mini Z GT
http://proevo cjb net
Mini Z GT's Avatar
Send a message via ICQ to Mini Z GT Send a message via Yahoo to Mini Z GT
Unhappy Damn screw on Kyosho Differential....
Today I went a little hardcore on my Mini Z. I went full throttle over a speed bump. My car survived that After i turned arround to come back to me and see if there was any damage and there was none. So i put my car back down to run arround and i noticed that my car only had one wheel turning, which was the wheel closest to the differential gear. So with closer examination i saw that I lost the damn screw on the other side of the differential. Now my car is only ONE wheel drive I lost the other spare screw that came with my Kyosho differential. So n e clues on how i can get another one??? I guess its back to stock differential
Mini Z GT
]Team: Project Evolution[/URL]
Project Altezza-Z
Mini Z GT is offline   Reply With Quote
Old 2002.05.30, 05:36 PM   #2
Russ
Super Moderator
Russ's Avatar
Yeah, they should have tons of them at your LHS. 3mm collar screw I believe is what they are called. I was in the same boat you were in, but I lost my GPM diff. collar screw, and both of the ones to my kyosho rear shock (which are the same size)
A pack of 4 or 5 should be like $0.99. I tried the hardware store first, but they didn't have any that small.
Russ
Old 2002.05.30, 05:56 PM   #3
Mini Z GT
Mini Z GT's Avatar
Talking
sWISH THANX I thought it was the end of the world and I'd have to spend a $hit load to get a new differential.
Mini Z GT
Project Altezza-Z
eztuner Kyosho Mini-Z AWD Pro Specs eztuner12 Mini-Z AWD MA-010, MA-015 14 2010.04.06 10:31 AM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 05:02 PM
Kyosho Differential jude26 Parts and Hop-ups 7 2003.12.28 12:14 PM
