Old 2007.07.28, 03:05 PM   #61
Limeaway
MA-010 Owner
Limeaway's Avatar
Send a message via AIM to Limeaway
Page 3...His target price is $75
Limeaway is offline   Reply With Quote
Old 2007.08.22, 12:33 AM   #62
Updates, finally.
The CNC stuff has finally come, after multiple threats on my part to file an eBay dispute. I got the CNC mill working, and ran a test program through it. Seems to work well, although I won't be able to see the tolerances until I build some prototype parts. At any rate, the thing IS working at least, so I can finally legitimately say I'm on my way to getting this chassis produced for those interested.
Old 2007.08.22, 06:31 AM   #63
byebye
byebye's Avatar
Cool man looking forward to some updates.
Kris
Old 2007.08.24, 03:25 AM   #64
Flashsp-2
motor guru
Flashsp-2's Avatar
It sucks that it took so long to get all the equipment in, but I'm excited to see some progress. I'm still in for a chassis, thats for sure. Already have the pan body, mounted/trued foams, and electronics ready to rock. You're still going 98mm correct?
Looking forward to seeing pics of some chassis parts
Old 2007.09.08, 05:26 PM   #65
First batch of G10 prototype parts! The cut quality is no good, but it's mainly because I used a ruined endmill to cut with. The holes will be countersunk later, no worries.
I plan to get these parts made correctly before moving on to the fancy 4-axis work, so check back for updates.
Old 2007.09.08, 07:32 PM   #66
Hammer
Mini-Z Electrician
Hammer's Avatar
Originally Posted by color01
First batch of G10 prototype parts! The cut quality is no good, but it's mainly because I used a ruined endmill to cut with. The holes will be countersunk later, no worries. I plan to get these parts made correctly before moving on to the fancy 4-axis work, so check back for updates.
Very cool, thanks for the update. Also thanks for sharing your learning process regarding manufacturing, it's a great resource for those interested but not familiar with how it's done.
My Gallery-My Movies
Hammer is offline   Reply With Quote
Old 2007.10.07, 05:32 PM   #67
I was using the wrong units! D'oh. I have the feed rates right this time, and edge quality is much better, though the cutting bit didn't go deep enough to separate the pieces entirely from the stock. (It turns out that this plate of fiberglass is slightly thicker than 1/32".)
If you look closely at the picture, you'll notice there are two "kinds" of edges. I was playing around with the settings and found that really slow speeds (6mm/min) are really good but take forever, slightly higher speeds (15-30mm/min) are terrible, and the proper speed (150mm/min) nets nearly perfect cuts (check the outside edges of the flex plates).
So that's my update. Since I have a 3-day weekend I should be able to do some more work on the fiberglass and get that all sorted out and perfect. The Delrin and aluminum parts may have to wait since I still need some screws to mount my micro vise to the rotary table. Rest assured I will get this done as fast as I possibly can!
Old 2007.10.08, 09:01 AM   #68
MikeL
Painter Guy
MikeL's Avatar
Very cool looking project, have you tested any standard electronics for fit? can you fit a novak spy and spektrum micro reciever on the top plate?
MikeL is offline   Reply With Quote
Old 2007.10.08, 03:33 PM   #69
Side by side, definitely. If you decased them both you might be able to fit one in front of the other. (I haven't checked that one yet)
The cleanest fit would actually be a Losi Micro-T board, but unless I'm forgetting something the chassis will also hold any Mini-Z board.
Old 2007.10.12, 12:48 AM   #70
Ok, I've got good and bad news.
Good news first: edge quality is perfect on the longer cuts.
Bad news: edge quality on the countersinks has gone down.
Worse news: the mill seems to jam up right around this one spot of travel. I have no idea where to look for the cure; the mill is freshly lubed up with WD-40 and the rails are clean. Yet there's a slight grinding noise and sometimes the whole thing just jams while the CNC control software believes it's still going.
Check Exhibit A:
Old 2007.10.12, 11:33 AM   #71
marc
Honda Insight Racer!
Hi there, do you have a way to check the gearing on the CNC machine? It might be gears binding or not meshing right. I dont' know anything about these machines, but knowing mechanics, it does sound like a gearing problem. Just a thought!
Old 2007.10.12, 01:44 PM   #72
ruf
4play
ruf's Avatar
WD40 is not a lube. Use grease.
Joe Chen
www.reflexracing.net
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2007.10.12, 07:08 PM   #73
I've been reprimanded for that multiple times now, lol... thanks ruf. I've lubed the machine and jogged it around the axes a couple times, hasn't jammed YET. I'll have to try running the program again to see where the problem area is. Will use styrene stock instead of wasting fiberglass.
Old 2007.10.12, 07:17 PM   #74
Hammer
Mini-Z Electrician
Hammer's Avatar
Absolutely correct, WD40 actually attracts moisture i.e. corrosion & rust.
Old 2007.10.13, 08:19 PM   #75
http://en.wikipedia.org/wiki/WD-40 Slight discrepancy...
Mill is still jogging smooth. I will be really, really frustrated if it jams during the test program tonight.
Intercontinental Racing using 3D RC Racing Blackno3 Red Hill Games 3D RC Racing 0 2008.02.26 06:44 PM
FS/T: KYOSHO / PN RACING PARTS MR01/F1/Overland kryten Mini-Z Marketplace 4 2008.02.19 05:09 PM
Different chassis minten Parts and Hop-ups 11 2004.02.04 02:07 AM
WTB Pro-Z Chassis and pn racing motor mount isk8blind Miscellaneous Discussion 0 2003.09.07 12:41 PM
Check out my custom Pro-Z chassis! efsee Aftermarket Chassis 9 2003.08.07 08:26 AM
