Old 2021.01.10, 01:04 PM   #1
New Nexx Racing Products 2021
This will follow relatively new manufacturer Nexx Racing for 2021.
Because I don't initially have parts available by date, going to throw up all that I know of and continue to update with new listings. No pricing, consult your local vendor for pricing please.
NX-001 Nexx Racing Mini-Z 2WD Solid Front Rim F0 (RED)
NX-002 Nexx Racing Mini-Z 2WD Solid Front Rim F1 (RED)
NX-003 Nexx Racing Mini-Z 2WD Solid Front Rim F2 (RED)
NX-004 Nexx Racing Mini-Z 2WD Solid Front Rim F3 (RED)
NX-005 Nexx Racing Mini-Z 2WD Solid Rear Rim R0 (RED)
NX-006 Nexx Racing Mini-Z 2WD Solid Rear Rim R1 (RED)
NX-007 Nexx Racing Mini-Z 2WD Solid Rear Rim R2 (RED)
NX-008 Nexx Racing Mini-Z 2WD Solid Rear Rim R3 (RED)
NX-009 "Nexx Racing Mini-Z 2WD LCG 98-102mm Alu 7075 Round
Motor Mount (RED)"
NX-010 "Nexx Racing Mini-Z 2WD LCG 98-102mm Alu 7075 Round
Motor Mount (ORANGE)"
NX-011 "Nexx Racing Mini-Z 2WD LCG 98-102mm Alu 7075 Round
Motor Mount (BLUE)"
NX-012 "Nexx Racing Mini-Z 2WD LCG 98-102mm Alu 7075 Round
Motor Mount (BLACK)"
NX-013 "Nexx Racing Mini-Z 2 WD MR015/02/03 LCG 98-102mm
Alu 7075 Square Motor Mount (RED)"
NX-014 "Nexx Racing Mini-Z 2 WD MR015/02/03 LCG 98-102mm
Alu 7075 Square Motor Mount (ORANGE)"
NX-015 "Nexx Racing Mini-Z 2 WD MR015/02/03 LCG 98-102mm
Alu 7075 Square Motor Mount (BLUE)"
NX-016 "Nexx Racing Mini-Z 2 WD MR015/02/03 LCG 98-102mm
Alu 7075 Square Motor Mount (BLACK)"
NX-017 Nexx Racing Mini-Z Lexan Pancar Body Carbon Front Bumper
NX-018 Nexx Racing Mini-Z Lexan GT Car Body Carbon Front Bumper
NX-019 Nexx Racing Mini-Z Lexan Body Post Carbon Plate Kit
NX-020 Nexx Racing Mini-Z Lexan Body Post Sensor Mount Carbon
NX-021 Nexx Racing Carbon Damper Dise
NX-022 Nexx Racing Mini-Z Carbon Damper Plate 98-102mm
NX-023 Nexx Racing Mini-Z MR03 Carbon T-Plate#2
NX-024 Nexx Racing Mini-Z MR03 Carbon T-Plate#3
NX-025 Nexx Racing Mini-Z MR03 Carbon T-Plate#4
NX-026 Nexx Racing Mini-Z MR03 Carbon T-Plate#5
NX-027 Nexx Racing V-Line Front Suspension System (RED)
NX-028 Nexx Racing V-Line Front Suspension System (ORANGE)
NX-029 Nexx Racing V-Line Front Suspension System (BLUE)
NX-030 Nexx Racing V-Line Front Suspension System (BLACK)
NX-112 Nexx Racing V-Line Front Suspension System (White)
NX-031 Nexx Racing Plastic Body Mount Post (4pcs)
NX-032 Nexx Racing Mini-Z Carbon Lexan Body Post Sensor Mount Damper Plate
NX-033 Nexx Racing Mini-Z 98-102mm Carbon Lexan Body Post Damper Plate
NX-034 Nexx Racing Alu Round Motor Mount Frame (Red)
NX-035 Nexx Racing Alu Round Motor Mount Frame (Orange)
NX-036 Nexx Racing Alu Round Motor Mount Frame (Blue)
NX-037 Nexx Racing Alu Round Motor Mount Frame (Black)
NX-038 Nexx Racing Carbon Plate#2 Round Motor Mount
NX-039 Nexx Racing Precision CNC Aluminum Damper Post (RED)
NX-040 Nexx Racing Motor Mount Ball Bearing Adapter (4pcs)
NX-041 Nexx Racing Mini-Z 2WD Solid Front Rim F0 (Neon Green)
NX-042 Nexx Racing Mini-Z 2WD Solid Front Rim F1 (Neon Green)
NX-043 Nexx Racing Mini-Z 2WD Solid Front Rim F2 (Neon Green)
NX-044 Nexx Racing Mini-Z 2WD Solid Front Rim F3 (Neon Green)
NX-045 Nexx Racing Mini-Z 2WD Solid Rear Rim R0 (Neon Green)
NX-046 Nexx Racing Mini-Z 2WD Solid Rear Rim R1 (Neon Green)
NX-047 Nexx Racing Mini-Z 2WD Solid Rear Rim R2 (Neon Green)
NX-048 Nexx Racing Mini-Z 2WD Solid Rear Rim R3 (Neon Green)
NX-049 Nexx Racing Mini-Z 2WD Solid Front Rim F0 (Neon Orange)
NX-050 Nexx Racing Mini-Z 2WD Solid Front Rim F1 (Neon Orange)
NX-051 Nexx Racing Mini-Z 2WD Solid Front Rim F2 (Neon Orange)
NX-052 Nexx Racing Mini-Z 2WD Solid Front Rim F3 (Neon Orange)
NX-053 Nexx Racing Mini-Z 2WD Solid Rear Rim R0 (Neon Orange)
NX-054 Nexx Racing Mini-Z 2WD Solid Rear Rim R1 (Neon Orange)
NX-055 Nexx Racing Mini-Z 2WD Solid Rear Rim R2 (Neon Orange)
NX-056 Nexx Racing Mini-Z 2WD Solid Rear Rim R3 (Neon Orange)
NX-057 "NEXX Racing Precision CNC 7075 Square Motor mount
for 98-102 LM (RED) "
NX-058 "NEXX Racing Precision CNC 7075 Square Motor mount
for 98-102 LM (ORANGE) "
NX-059 "NEXX Racing Precision CNC 7075 Square Motor mount
for 98-102 LM (BLUE) "
NX-060 "NEXX Racing Precision CNC 7075 Square Motor mount
for 98-102 LM (BLACK) "
NX-061 "NEXX Racing Precision CNC 7075 Round Motor mount
for 98-102 LM (RED)"
NX-062 "NEXX Racing Precision CNC 7075 Round Motor mount
for 98-102 LM (ORANGE)"
NX-063 "NEXX Racing Precision CNC 7075 Round Motor mount
for 98-102 LM (BLUE)"
NX-064 "NEXX Racing Precision CNC 7075 Round Motor mount
for 98-102 LM (BLACK)"
NX-065 "NEXX Racing Precision CNC 7075 Round Motor Mount
for 90-94mm RM (RED)"
NX-066 "NEXX Racing Precision CNC 7075 Round Motor Mount
for 90-94mm RM (ORANGE)"
NX-067 "NEXX Racing Precision CNC 7075 Round Motor Mount
for 90-94mm RM (BLUE)"
NX-068 "NEXX Racing Precision CNC 7075 Rount Motor Mount
for 90-94mm RM (BLACK)"
NX-069 NEXX Racing CNC Aluminum 2mm Washer (4pcs) (RED)
NX-070 NEXX Racing CNC Aluminum 2mm Washer (4pcs) (ORANGE)
NX-071 NEXX Racing CNC Aluminum 2mm Washer (4pcs) (BLUE)
NX-072 NEXX Racing CNC Aluminum 2mm Washer (4pcs) (BLACK)
NX-073 Nexx Racing Precision CNC Aluminum Damper Post (ORANGE)
NX-074 Nexx Racing Precision CNC Aluminum Damper Post (BLUE)
NX-075 Nexx Racing Precision CNC Aluminum Damper Post (BLACK)
NX-077 Nexx Racing Dual Lipo Carbon Chassis Conversion Kit (RED)
NX-111 Nexx Racing Dual Lipo Carbon Chassis Conversion Kit (BLACK)
NX-078 Nexx Racing Carbon Top Plate Square Motor Mount
NX-079 Nexx Racing Aluminum Square Motor Mount Frame (Red)
NX-080 Nexx Racing Aluminum Square Motor Mount Frame (Orange)
NX-081 Nexx Racing Aluminum Square Motor Mount Frame (Blue)
NX-082 Nexx Racing Aluminum Square Motor Mount Frame (Black)
NX-083 TAIL SHOCK
NX-084 Nexx Racing Lock Nut King Pin Set for V-LINE
NX-085 "DRIVE ARM (RED)
(0 degree)"
NX-086 "DRIVE ARM (RED)
(0.5 degree)"
NX-087 "DRIVE ARM (RED)
(1 degree)"
NX-088 NEXX-V-LINE-ARM UPPER BRACKET (RED)
NX-089 "Nexx Racing Aluminum Low Down Knuckle Set For V-LINE
(RED)"
NX-090 CAM SHAFT
NX-091 "NEXX-V-LINE-CAMPER UPPER-ARM
Left and Right (RED)"
NX-092 "NEXX-V-LINE-CAMPER-LOWER-ARM
NX-093 Nexx Racing Mini-Z 2WD Solid Front Rim F0 (BLACK)
NX-094 Nexx Racing Mini-Z 2WD Solid Front Rim F1 (BLACK)
NX-095 Nexx Racing Mini-Z 2WD Solid Front Rim F2 (BLACK)
NX-096 Nexx Racing Mini-Z 2WD Solid Front Rim F3 (BLACK)
NX-097 Nexx Racing Mini-Z 2WD Solid Rear Rim R0 (BLACK)
NX-098 Nexx Racing Mini-Z 2WD Solid Rear Rim R1 (BLACK)
NX-099 Nexx Racing Mini-Z 2WD Solid Rear Rim R2 (BLACK)
NX-100 Nexx Racing Mini-Z 2WD Solid Rear Rim R3 (BLACK)
NX-101 "NEXX Racing Precision CNC 7075 Round Motor mount
for 98-102 LM (SILVER)"
NX-102 "NEXX Racing Precision CNC 7075 Rount Motor Mount
for 90-94mm RM (SILVER)"
NX-103 "NEXX Racing Precision CNC 7075 Square Motor Mount
NX-104 "NEXX Racing Precision CNC 7075 Square Motor Mount
NX-105 "NEXX Racing Precision CNC 7075 Square Motor Mount
NX-106 "NEXX Racing Precision CNC 7075 Square Motor Mount
NX-107 NEXX Racing Alu Front Suspension Spacer (BLACK)
NX-108 Nexx Racing Traffic Cones (10pcs)
NX-109 Nexx Racing Mini-Z 2WD Solid Rear Rim R14 (RED)
NX-113 Nexx Racing V-Line Front Suspension Spring Set (4 pair)
NX-114 "NEXX Racing Precision CNC 7075 Square Motor mount
for 98-102 LM (SILVER) "
NX-115 Nexx Racing M2 Lock Nut (4pcs) (RED)
NX-116 Nexx Racing SKYLINE Dual Lipo Carbon Chassis Conversion Kit For MR03 (ORANGE)
NX-117 Nexx Racing SKYLINE Dual Lipo Carbon Chassis Conversion Kit For MR03 (BLUE)
NX-118 Nexx Racing SKYLINE Dual Lipo Carbon Chassis Conversion Kit For MR03 (SILVER)
NX-119 NEXX Racing Banner
NX-121 NEXX Racing Precision CNC 7075 Square Motor Mount for 90-94mm RM (SILVER)
NX-122 "Nexx Racing Aluminum Low Down Knuckle Set For V-LINE
(ORANGE)"
NX-123 "Nexx Racing Aluminum Low Down Knuckle Set For V-LINE
(BLUE)"
NX-124 "Nexx Racing Aluminum Low Down Knuckle Set For V-LINE
(BLACK)"
NX-125 "Nexx Racing Aluminum Low Down Knuckle Set For V-LINE
(SILVER)"
NX-126 Nexx Racing Mini-Z MR02/03 CNC 64P Spur Gear Ceramic Ball Diff
NX-127 Nexx Racing CNC Mini-Z 64P Delrin 53T Spur Gear
NX-128 Nexx Racing GT Lexan Body Mount - Damper Plate
NX-129 Nexx Racing Lexan Pancar Body Mount - Damper PLate
NX-130 Nexx Racing Dual-Spring Precision Bearing Center Shock (RED)
NX-131 Nexx Racing Dual-Spring Precision Bearing Center Shock (ORANGE)
NX-132 Nexx Racing Dual-Spring Precision Bearing Center Shock (BLUE)
NX-133 Nexx Racing Dual-Spring Precision Bearing Center Shock (BLACK)
NX-134 Nexx Racing Dual-Spring Precision Bearing Center Shock (SILVER)
NX-135 Nexx Racing Team T-Shirt Size M
NX-136 Nexx Racing Team T-Shirt Size L
NX-137 Nexx Racing Team T-Shirt Size XL
NX-138 Nexx Racing Team T-Shirt Size XXL
NX-139 Nexx Racing 3/32 Ceramic Ball
NX-140 Nexx Racing CNC Brass Caster Bar For V-Line
NX-141 Nexx Racing Mini-ZMR02/03 Multilength Carbon Disk Damper For Lexan (RED)
NX-142 Nexx Racing Mini-ZMR02/03 Multilength Carbon Disk Damper For Lexan (ORANGE)
NX-143 Nexx Racing Mini-ZMR02/03 Multilength Carbon Disk Damper For Lexan (BLUE)
NX-144 Nexx Racing Mini-ZMR02/03 Multilength Carbon Disk Damper For Lexan (BLACK)
NX-145 Nexx Racing Mini-Z MR02/03 Multilength Carbon Disk Damper Set (RED)
NX-146 Nexx Racing Mini-Z MR02/03 Multilength Carbon Disk Damper Set (ORANGE)
NX-147 Nexx Racing Mini-Z MR02/03 Multilength Carbon Disk Damper Set (BLUE)
NX-148 Nexx Racing Mini-Z MR02/03 Multilength Carbon Disk Damper Set (BLACK)
NX-149 Nexx Racing Spring Set For Dual-Spring Precision Bearing Center Shock (8pcs)
NX-150 Nexx Racing Inox Micro Ultra Body Clip (10pcs)
NX-151 Nexx Racing Damper Springs
NX-152 Nexx Racing High Quality Polished Pressure Plate (2pcs)
NX-153 Nexx Racing Stainless Steel Hexagon Socket Set Screw M2x3 (4pcs)
NX-154 Nexx Racing Hexagon Socket Set Screw M3x3 (6pcs)
NX-155 Nexx Racing CNC 7075 Alu Upper Frame For Kyosho MR03 (RED)
NX-156 Nexx Racing CNC 7075 Alu Upper Frame For Kyosho MR03 (ORANGE)
NX-157 Nexx Racing CNC 7075 Alu Upper Frame For Kyosho MR03 (BLUE)
NX-158 Nexx Racing CNC 7075 Alu Upper Frame For Kyosho MR03 (BLACK)
NX-159 Nexx Racing CNC 7075 Alu Upper Frame For Kyosho MR03 (SILVER)
NX-160 Nexx Racing CNC 7075 Alu Hop Up For PN 2.5 (RED)
NX-161 Nexx Racing CNC 7075 Alu Hop Up For PN 2.5 (ORANGE)
NX-162 Nexx Racing CNC 7075 Alu Hop Up For PN 2.5 (BLUE)
NX-163 Nexx Racing CNC 7075 Alu Hop Up For PN 2.5 (BLACK)
NX-164 Nexx Racing CNC 7075 Alu Hop Up For PN 2.5 (SILVER)
NX-165 Nexx Racing 7075 Alu Tail Spring Support For V-Line
NX-166 Nexx Racing Stainless Steel Pin Of Tail Support For V-Line
NX-167 Nexx Racing Stainless Steel Ride Height Adjust For V-Line
NX-170 Nexx Racing Brass Bottom Plate For SKYLINE
NX-171 Nexx Racing Mini-Z 2WD Solid Rear Rim R14 (Neon Orange)
NX-172 7075-T6 Alu Hard-Anodized 9T-64P Pinion
NX-173 7075-T6 Alu Hard-Anodized 10T-64P Pinion
NX-174 7075-T6 Alu Hard-Anodized 11T-64P Pinion
NX-175 7075-T6 Alu Hard-Anodized 12T-64P Pinion
NX-176 Nexx Racing Traffic Cones (10pcs) Neon Orange
Microsoft MIX 2011 - Mini-Z racing mdowney Events 51 2011.04.25 08:30 PM
PN Racing new products. Ton PN Racing 5 2007.07.11 01:43 PM
Eagle Racing products gcmartinez Parts and Hop-ups 3 2007.06.25 06:34 PM
Atlanta Mini Scale Racing Announcement AtlRC Atlanta Mini Scale Racing 43 2006.02.19 07:52 AM
RC Racing Products?? Gimpdiggity Parts and Hop-ups 6 2002.03.15 06:54 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
