Old 2004.03.22, 06:17 PM   #1
turbodrifter
Mini-Z Novice
water submergable ol
I want to make an overland that i can drive in deep water. all my other ol's are very high off the ground so they can travel over water without the electronics getting submerged. but i want an overland that can be completely submerged, electronics and all.
im working on water tight casing that will cover the electronics, and im going to cover all but the tip of the antenna in a plastic guard(maybe a drinking straw). it should be able to drive through a pretty deep trench as long as some of the antenna is accesable.
any ideas on how to make it more suitable for water obstacles?
-overland rock crawler
-overland jumper
-overland monster
-mini z racer mr-01
-4 xmods
turbodrifter is offline   Reply With Quote
Old 2004.03.22, 06:28 PM   #2
ridealot100
Send a message via AIM to ridealot100
I THINK YOU ARE INSANE!!!!!
lol i am way to careful with my ol
umm try that plastic dip stuff maybe??
My mini-t hs-55 servo
Mamba 5400kv brushless motor r142je futaba rec.
bearings 6 cell gp batt pack
oil shocks
I LOVE MINI-TS!AND COWBOY BEBOP!
ridealot100 is offline   Reply With Quote
Old 2004.03.22, 06:36 PM   #3
turbodrifter
Mini-Z Novice
lol, yeah its a pretty crazy idea, i just think it would be neat, even if i dont take it really deep it mud and water splash up i want my ol safe. besides this is my 4th ol, so i think its time to be a little bit more crazy with my ideas.
-overland jumper
-overland monster
-mini z racer mr-01
-4 xmods
Old 2004.03.22, 10:42 PM   #4
Stoovey
People thought I was nuts for waterproofing my E-Maxx (or most of it...). Wow, an OL?! Go for it!!
Stoovey is offline   Reply With Quote
Old 2004.03.22, 11:35 PM   #5
turbodrifter
Mini-Z Novice
thanks, im gana give it a shot
-overland jumper
-overland monster
-mini z racer mr-01
-4 xmods
Old 2004.03.23, 12:21 PM   #6
RedRSX
Bahrain GP - 04/04/04
RedRSX's Avatar
Send a message via AIM to RedRSX
um...i dont really know where you would start on that project...another thing, if you have ever tried to take an OL through any wet mud that is pretty deep, it does not fair very well...remember the lack of weight these have and the fact they are 2WD...you wont be doing anything amazing in it, i can tell you that
My Gallery
- Custom Black Land Crusier, LSSM Lift, Silver Alloy Main Gear Cover, Silver Alloy Motor Heatsink, Silver Alloy Battery Clips, Silver Alloy Knuckles, Gunmetal Alloy Rims, Silver Alloy Underguard, Silver Alloy Front and Rear Suspension Mounts, Silver Alloy Front and Rear Gearboxes, Super U Swamper Tires
RedRSX is offline   Reply With Quote
Old 2004.03.23, 01:01 PM   #7
Draconious
Draconious's Avatar
Well do you literealy want to submerge it, or just keep it splash safe?
if you actualy want to submerge it... dont expect it to last long no matter what you do to it, metal parts will rust and corrode.. on it... bearings will jam... motor will get gunky and need cleaingin every run... but you could just dip the whole PCB in plastic dip.. leaving a power attachment for the motor etc... but you should rig some sort of heat sink on it... that you can shave the plastic coating off of to expose the sink... the servo case would need to be totaly sealed, and thats impossible if u want the tie rod to function...
if you just wnat splash protection, just shrink wrap the PCB, and seal all but the tie rod holes in the servo case and go...
Old 2004.03.23, 01:03 PM   #8
racer_d
Overland Over where?
racer_d's Avatar
I wouldn't advise driving in water but get some silicone and put in every crack like take apart the chassis put a bead in between every seam and youll be be fine
and there is also a type of grease that can be put directly on the circuits its meant for computers they submeresd a whole computer in a giant tank and it still worked
but i can't remember the name of it also remember to seal the servo box to.
and unless there seams you forgot you should be fine.
but the batts might short.
WooT I just got my first ride a 95 4RUNNER Red
Check out [/color][/URL] It has all kinds of crazy stuff. I promise you'll love it
racer_d is offline   Reply With Quote
Old 2004.03.23, 02:50 PM   #9
easy
easy's Avatar
Automotive stores will probably have a special grease for ignition systems that might work too. It could be the same stuff they used on the computer in a different tube.
That grease was made not to damage electronics, I used it in the distributor cap leads of my '82 Mustang GT to help prevent problems in our wet coast Vancouver weather.
It could probaply work for you to and I don't recall it being very expensive. Sorry I don't recall the name and it is burried in storage. It might have been specifically for Ford ignition systems which might help you track it down.
easy is offline   Reply With Quote
Old 2004.03.23, 07:46 PM   #10
DogbreathRacing
MINI-Z MONSTER GARAGE
DogbreathRacing's Avatar
Let me know when you try it........I'll buy the chassis and suspension parts that are left over...........
THESE WERE NOT MEANT TO GET WET!
MR02RM, MR02MM, MZM,
Pro-Pulse Pro T-100 1/18 4X4,
Old 2004.03.23, 09:18 PM   #11
easy
easy's Avatar
Actually the idea may not be all that unreasonable. Keep in mind they make those little submarines that are not very expensive. RC boats have been arount a long time too.
We used to watch them at the annual boat show at the CNE in Ontario every year back in the '70's. Ehh... I guess I just dated myself eh?
Any how they must have developed ways to seal things up water tight for the inevitable flipping and sinking of rc hydro planes and such. Same deal with sea planes you just know they end up nosing into the water but survive so I'd say check an lhs that's into boats.
As for the servo lever a cv type boot with some grease will do the trick and the motor box can likley be sealed too. Don't use oil shocks and loose your bearings for the swamp buggy. Mind you its not like they are difficult to flush out with WD40.
If you do make it water proof after running it through the water you can just drop it in a bucket of WD40 afterwards. I'll agree its risky business but it's not impossible. Don't forget to put a snorkle on one of the A pillars because it just ain't a swamper without a snorkle.
Old 2004.03.25, 11:04 AM   #12
terry beebe
R/C expert
terry beebe's Avatar
if you live around a boat marina or dealer they have this special oil that you just put on allover the electronics & metal parts that displaces water. everything works fine even totaly submerged, use it on my rc boats, you just have to reapply it often depending on how wet you want to get. it's called THE STUPH and its pricey. good luck & happy motoring!!!
terry beebe is offline   Reply With Quote
water slide decals cbizz Custom Bodies 3 2007.07.06 11:28 AM
Mini-ZRacer.com Parts Color Vote mini-z Parts and Hop-ups 110 2006.10.19 03:39 PM
Monster + Water = Broken :( jude26 Mini-Z Monster MM-01 20 2004.09.27 10:14 AM
Another Water Breaking In Motor Question 95_civic_gsr Motor Tech 25 2003.07.05 04:12 AM
breaking in motor- water method?'s Sinister® Beginner Questions 2 2003.06.21 07:25 AM
