Old 2007.07.05, 08:32 AM   #1
cbizz
water slide decals
I just picked up some water slide decals and I have no clue how they work. Do you need to buy anything special to apply them? Iíve read something about water slide decal transfer paper.. Is this a must? Anybody with tips or suggestions would be greatly appreciated.
Thanks in advance
cbizz is offline   Reply With Quote
Old 2007.07.05, 08:46 AM   #2
im8im8
Bring Up Da Rear
Thanks in advance
you can get away with printing them using an inkjet printer and put a clear coat on the decal to prevent the ink form the injk from running. After it drys just cut around your decal print. Place it in water for about 15-30 seconds. By that time the decal should separate away from its backing which will allow you to apply it to the car body.
If you want a rigorous way of applying waterslide decal then just google search. However I have been able to get away with doing it the quick away with only the occasional time when the ink runs.
im8im8 is offline   Reply With Quote
Old 2007.07.05, 11:58 PM   #3
Tweaksalot
Tweaksalot's Avatar
Send a message via AIM to Tweaksalot Send a message via Yahoo to Tweaksalot
q-tips help during the process to soak up the water and smooth the decals when applying it on to the body.
Tweaksalot is offline   Reply With Quote
Old 2007.07.06, 11:28 AM   #4
cbizz
Thanks, you guys have been a big help
Experts on decals lfisminiz Custom Bodies 8 2006.12.03 08:47 PM
General Lee Basher carfreak_22 Custom Bodies 20 2006.09.20 07:02 PM
Directions for internal fixing of waterslide decals on lexan bda52 Custom Bodies 5 2005.06.15 09:58 AM
Decals, Decals and more Decals..... geoffrey109 Parts and Hop-ups 7 2005.03.30 12:01 AM
Another Water Breaking In Motor Question 95_civic_gsr Motor Tech 25 2003.07.05 04:12 AM
