Old 2008.04.04, 05:03 AM   #1
Programmers
iTomCash
Noob Question... Offsets
I've just dropped my wheel box and all my wheels are mixed up.
Apart from trying determine if the little stub where the knuckle fits is 1mm bigger than the others, how can I work out what wheels are what offset?
Surley there has to be a better way.
Thanks,
Tom.
Old 2008.04.04, 05:24 AM   #2
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
the dish,0 are flat and so on,try and pair them up by eye and you will see what i mean
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.04.04, 06:06 AM   #3
Programmers
iTomCash
Oh dear lol... That's not too easy. >.< I've got 1.5's in there too lol!
Old 2008.04.04, 07:02 AM   #4
kryten
kryten's Avatar
Would standing them up,knuckle side down help? It may be easier to judge the gaps(offsets) that way.
Old 2008.04.04, 08:03 AM   #5
andreophile
Left Foot Braker
andreophile's Avatar
If you pay attention to the front track width mentioned in the manual, it's said to vary from 56.5mm to 63.5mm with respect to narrow wheels for the MA-010 Scooby RTR set. That's because the front track measures 56.5mm when you employ 0 offset narrow wheels (0 + X + 0 = 56.5mm) and it increases by 7mm to a maximum of 63.5mm when outfitted with 3.5 offset narrow wheels (3.5 + X +3.5 = 63.5mm). Where X is the length from one knuckle to the another.
This way, you just have to plonk the wheels onto the front axles and measure the track to get an accurate value of their offset. Wide and semi-wide wheels should be compensated accordingly.
andreophile is offline   Reply With Quote
Old 2008.12.20, 09:55 PM   #6
ProfoxCG
Send a message via AIM to ProfoxCG
on an AWD actually when outfitted with N 0 offset the track width is
65.0 mm
With W 0 offset track width is 70.00 mm
I got this information for an official Kyosho reference sheet included in an AWD autoscale.
KO EX-1ur | MR02 Spec 0 | dNano Type 1
ProfoxCG is offline   Reply With Quote
Old 2008.12.22, 03:55 PM   #7
andreophile
Left Foot Braker
That's weird, because I got those numbers off the box of my MA-010 RTR set. I think it also factors in negative wheel offsets in the wide range of offset gamut that is mentioned there.
Old 2008.12.22, 08:22 PM   #8
ProfoxCG
I don't know, i confirmed the info i have though on my homemade setup board
will post a pic soon.
Noob Question About F! Tires stardust39 Mini-Z F1 MF-010, MF-015 1 2008.02.12 09:45 PM
Could anyone print purple question marks for me? Spoon Custom Bodies 3 2006.10.16 10:50 PM
Quick Noob Question... james399 Mini-Z Overland MV-01 1 2005.09.26 04:21 AM
Extremely Dumb Question theJumpoff Beginner Questions 4 2005.08.18 11:35 AM
Anyone have these wheels? I have a question PoorZDriver Mini-Z Racer MR-02 2 2005.01.06 12:55 PM
