Old 2009.05.31, 06:19 PM   #1
bmxtrev
MidWest Racers
bmxtrev's Avatar
Send a message via AIM to bmxtrev Send a message via MSN to bmxtrev
Atomic Top Shock Help
I got the atomic alloy top shock, adjustable for 94 and 98. When threading the black shaft onto the metal rod, it required so much force that i ended up twisting the black plastic shaft in half. So now im stuck with the 98mm black shaft, which was also impossible to get threaded on correctly [its on though], and i am just wondering if there is any way i can use the 98mm shaft for both 94 and 98mm. Or if you have any other info about the shock that would benefit please do tell
thanks
trev
Team MwR
ReflexRacing
bmxtrev is offline   Reply With Quote
Old 2009.05.31, 11:16 PM   #2
bamaboy379
bamaboy379's Avatar
I am not sure about the problem you have mow but once you fix that check out the tuning article called Atomic Top Shock Mods at www.fastpaceracing.com under tuning section.
bamaboy379 is offline   Reply With Quote
AD Band motor with 2.4ghz? tosh Mini-Z Science 6 2009.05.17 06:58 AM
WTT Atomic SAS for Aluminum Rear Top + Bottom Peices arch2b Mini-Z Marketplace 5 2007.12.02 01:59 AM
Many Atomic AWD parts for sale! pchan0 Miscellaneous Discussion 10 2006.10.26 10:29 AM
Anybody interested in a AD band car set up? pchan0 Miscellaneous Discussion 8 2005.12.29 10:57 PM
Eagle Mono Oil Shock - Help!! CedMan Parts and Hop-ups 8 2002.08.17 04:27 PM
