Old 2002.09.19, 05:55 PM   #1
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Rear Susp. Plate Rally Spacers
I haven't tried this, but it seems simple enough. It doesn't have to be as complicated as in the rendering. Perhaps it could even be done using two of the triangle spacers. Maybe not. It'd probably be easier to just scratch build them.
Old 2002.09.19, 05:57 PM   #2
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
doh, attaching the rendering might help.
Old 2002.09.19, 06:01 PM   #3
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
The angle in the render is extreme but arbitrary. It doesn't need to be that steep to be effective and increase clearance.
Modifying two triangle spacers might be easier afterall.
edit: Sheesh, make up your mind you flighty bastard.
Old 2002.09.20, 02:40 AM   #4
butler
Mini-Z Chief
butler's Avatar
Send a message via MSN to butler
I would say the angled approach is better. Its more likely to slide over stones than adding another traingle plate.
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
butler is offline   Reply With Quote
Old 2002.09.21, 10:51 AM   #5
Billiam_Returns
Billiam_Returns's Avatar
Send a message via AIM to Billiam_Returns
You would have to have the high motor mount. The low CG one would be scraping on the ground! Also what would you do about groung clearance of the diff and all that?
- pretty lame right now...
Billiam_Returns is offline   Reply With Quote
Old 2002.09.21, 11:00 PM   #6
mini-z
Administrator
mini-z's Avatar
Wow Ken, I like it!
Old 2002.09.21, 11:29 PM   #7
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Thanks Mini-Z.
Billiam,
I make the note to use the high motor mount in the rendering.
For the diff clearance, use a 40t spur and a large wheel set.
That should give a little more space. I imagine if there's any rally racing happening, it would be on packed dirt anyway. The Z is too small for much of anything else.
Old 2002.09.21, 11:34 PM   #8
Draconious
Draconious's Avatar
I thought of using my broken stock plate for a angled shim was going to grind it with dremel... I was going to use a 180 mount length plate though.. the angle would help it rotate 180... as long as the angle aint too steep the screw hole area wont realy interfear with ground clearance.
It wuld be better if Kyosho just released a motor pod with the screw holes moved under the motor pod area... and use it as a 180 mount, but not low, or high, sort of inbetween. (isnt the VW this way?)
Old 2002.09.22, 05:12 AM   #9
Kid_CojoneZ
Guest
Posts: n/a
I was thinking of something similar, just sanding down the triangle, i wouldn't knwo where to get a smaller spur gear...
Old 2002.10.06, 10:27 PM   #10
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Scott,
You told me to contribute towards the rally effort.
What's the status on your project?
Old 2002.10.07, 06:16 AM   #11
ScottMcLeod
Send a message via ICQ to ScottMcLeod Send a message via AIM to ScottMcLeod Send a message via Yahoo to ScottMcLeod
Waiting for machined arms from Pimp24s (on AIM)
I forget who he is on the forums, i'm sure he'll show up and remind me. (i'm really bad with names, as you can see)
Once I get the arms, they need to be dremmeled to shape (they'll come like stock arms, with extra metal on the bottom)
This spacer might be the solution though... I need to dremmel up some parts, and right now we're going through midterms :-(
-Scott
ScottMcLeod is offline   Reply With Quote
Old 2002.10.07, 05:07 PM   #12
DOHCrazy
DOHCrazy's Avatar
Send a message via ICQ to DOHCrazy Send a message via AIM to DOHCrazy Send a message via Yahoo to DOHCrazy
lol...scott u cant be that bad at names... i gave the plans to that guy and once hes done with this water coolent system for my pc then he'll get to work! (he should be done with the arms soon!)
A toast for bread, For without bread there would be no toast!
AIM: DOHCrazy Email: NS83@juno.com 2nd: dohcrazy@swbell.net
DOHCrazy is offline   Reply With Quote
WTB broken/damaged MA010 chassis and topcad rear lower carbon plate sciencemike Miscellaneous Discussion 1 2006.05.10 05:46 PM
MR02 rear suspension plate Impala SS Parts and Hop-ups 2 2005.08.18 12:47 PM
I just bought an F1!!!!! RedRSX Mini-Z F1 MF-010, MF-015 11 2004.03.19 10:45 AM
Product Review: the CLK Front Bumper Plate West.F1 Parts and Hop-ups 6 2003.02.27 10:49 PM
Softening Rear Suspension Plate (H Plate) Justin Parts and Hop-ups 4 2002.01.17 04:49 AM
