Old 2011.07.21, 03:59 PM   #1
thestug
thestug's Avatar
2.4ghz problem
Ok, this is not exactly a mini-z problem, but it is a mini-z board. I have a Losi micro SCT with 2.4ghz mini-z electronics. The problem I have been having is the motor will only work for a few seconds at a time and then stop. The motor is a stock losi micro motor and the battery is a 7.4v 250mah Lipo battery. What would cause the car to run and stop after a few seconds. Also it will run as long as I don't stop. If I stop the car's motor will stop responding, but the servo still works so it is recieving the signal. I also can't brake or reverse because that involves returning the throttle to a neutral position. Anyone know what is wrong?
Some say he never blinks, and that he roams around the woods at night foraging for wolves... all we know is, he's called The Stug.
thestug is offline   Reply With Quote
Old 2011.07.21, 04:02 PM   #2
reaper
reaper's Avatar
sounds like the thermal overload is kicking in
tryed a tamer motor ?
reaper is offline   Reply With Quote
Old 2011.07.22, 08:38 AM   #3
thestug
thestug's Avatar
The motor should be pretty tame its a stock losi micro motor, which is smaller than the 130 size mini-z motors. I would think that this motor wouldn't draw much current, but I could be wrong. Anyway I think I'm going to try a different stock motor.
Old 2011.07.22, 10:15 AM   #4
reaper
reaper's Avatar
the losi motors are a lower wind (and smaller coils) than a regular 130 size motor thats why a losi micro board has a 2x fet stack
try it with a 130 size xmod or mini-z motor just to see
Problem with 2.4Ghz ASF Board or KT-18 ?? s_m_z 2.4GHz ASF System (Auto Selected Frequency) 2 2010.02.22 01:57 AM
2.4Ghz Servo/Steering Problem addicted Mini-Z AWD MA-010, MA-015 30 2009.10.29 01:06 PM
*Help* 2.4ghz install problem Faze 2.4GHz ASF System (Auto Selected Frequency) 6 2009.07.06 10:35 PM
Signal problem with my RF901-SM Mini-Z 2.4ghz module for Helios Felix2010 KO PROPO 6 2008.12.19 12:02 PM
2.4GHz Steering problem rcmorris 2.4GHz ASF System (Auto Selected Frequency) 3 2008.08.10 10:13 AM
