Old 2016.01.04, 01:15 PM   #1
Kyosho Syncro EX-6 FAQ
Kyosho Syncro EX-6
No.82030
Kyosho Webpage
Kyosho Instruction Manual
New technology MHS 2.4GHz system delivers the fastest, most functional high-end transmitter in the history of the Mini-Z.
Backward compatibility allows the transmitter to be switched to the pre-existing ASF 2.4GHz system.
Equipped with the rich functionality expected of a high-end transmitter.
Features 2.7-inch display screen. Language options include English and Japanese. (Firmware update provide English only language option)
Old 2016.03.27, 08:20 AM   #2
can anyone confirm K.I.Y. accessories are meant for this transmitter or is there a separate line of accessories for the EX-6? The EX-2 webpage references K.I.Y. accessories specifically.
Old 2016.03.27, 08:31 AM   #3
KWT
Q. Can I use optional parts for EX-1 with the EX-2?
A. Yes, you can use KIY compatible part for the EX-2.
KIY compatible optional parts
>Steering Unit
10549 Drop Extension Unit
10501 3D Extension Unit for KIY
10502 ST Unit Stick Type for KIY
10525 Steering Sponge for KIY
10542 Steering Wheel EX-1 K.I.Y
10506 Steering Unit EX-1
>Grip Unit
10546 Battery stand Unit
10526 Expert Grip(right)
10527 ExpertGrip (left)
10528 Color Grip2 ( Wine Red)
10529 Color Grip2( Black)
10530 Color Grip2( Gray)
10531 Color Grip2( Green)
10532 Color Grip2 (Blue)
10509 Counter Weight 42.0g + 14.4g
10510 Color Grip Wine Red for KIY
10511 Color Grip Black for KIY
10512 Color Grip Gray for KIY
10513 Color Grip Green for KIY
10514 Large Grip Gray for KIY
10515 Large Grip Green for KIY
10503 Large Grip Black for KIY
>Master Unit
80543 Master Unit EX-1FHSS Ver2 with KR-413FH
80522 Master Unit EX-1 ASF Ver.2
Note: Can not use the ”LCD color Panel”. You can only use the color screws set for the Grip Unit.
http://www.kopropo.co.jp/sys_en/radi...ex-2/ex-2.html
Old 2016.03.31, 08:59 PM   #4
KWT
A little more information that applies to both the EX-2 and EX-6. If you remove the Xpansion module, the Transmitter will act like a single memory model unit with limited adjustments.
Old 2017.06.06, 04:34 PM   #5
refsiul22
refsiul22's Avatar
Syncro EX-6 Hipoint
Hi guys. How can I set the Throttle Hipoint in this Tx? I have used this my previous Helius Ex-10 and KIY Ex-1. But haven't found that on this radio yet?
Also there's a "FEEL" function that I don't understand. Has anyone experienced with that?
Old 2017.06.08, 05:45 PM   #6
RussF
Salt Lake Mini-Z
RussF's Avatar
Throttle Travel. Page 43 of the manual has the throttle settings. Feel is kind of like dual rate, curve, expo or similarly named features. It dulls or sharpens the feel of the setting. There's one for steering and one for throttle. + settings are more feel and - settings are less. Page 42 for steering and 47 for throttle.
Salt Lake Mini-Z
RussF is offline   Reply With Quote
Old 2017.06.13, 04:49 PM   #7
refsiul22
refsiul22's Avatar
TH settings
What are you using for TH hipoint? Default comes at 100 (0 - 150)
For the FEEL settings, I guess I have to test it at the track.
Thanks
Old 2017.06.13, 06:31 PM   #8
bobbyz
Others can verify, but I've noticed that the TH hipoint doesn't increase speed going past 70ish. Do others notice the same thing?? I typically have my HFAY car set at 60-65 depending on the track.
Old 2017.06.14, 05:04 PM   #9
RussF
Salt Lake Mini-Z
RussF's Avatar
Thanks
I'm not sure since I leave my gear at the track but I would guess somewhere around 70-80.
Yes this is a fact and is the same on the EX-10 as well. I describe it to racers this way. If 100% throttle is the goal the throttle end point dictates how far the trigger moves before getting to full throttle. So a setting of 70ish means that the trigger will reach full throttle at its farthest limit. A setting of 100 or more means that you will reach full throttle somewhere sooner like at about the 50% of the trigger range. Some like it that way as they need to move the trigger less. Some, like me dont like it that way and want to have more range. Hope that makes sense.
Salt Lake Mini-Z
Old 2017.06.16, 12:12 AM   #10
refsiul22
refsiul22's Avatar
Definitely helpful. I raced last time with TH HP at 80. Next time, I will try the 70-80s range.
So far, I've had a great experience (results) with this radio. Feels so nice and comfortable compared to EX-10 and EX-1 KIY, which are the radios i've owned so far.
Old 2018.04.28, 02:20 PM   #11
TPDazzle
Does anyone know where I can buy a reciever for EX-6r? I am thinking about getting one, but I would like to use it with my 1/10th scale as well. I looked around online and didn't have much luck, but I could have missed something.
EDIT: info from Ko ProPo is below, I haven't checked, but I'm guessing the stuff they mention would cost more than a new radio from a different brand.
You would need to purchase the EX-2 Master Unit (80559) since the frequency modulation is different. Also either the Xpansion Unit 104 (80559) or Xpansion Unit 104S (10580). The Xpansion units are the LCD screens. 104 is what comes with the EX-2, 104S is what comes with the EX-RR. The functions included are a little different.
Old 2021.04.24, 03:03 PM   #12
xmodcanuck
To add some potential useful information
KO Propo EX-1 KIY 3D Expert Grip Trigger KOP16064
Apparently this is the trigger for the EX-6. Potentially for some but not all EX-6 as I was asked for a pic when I asked which trigger was correct.
shop.tinyrc.com: New Year, Tons of New Products! Mrs Mini-Z Newsletters 0 2013.02.06 07:33 AM
Different coded / keyed Kyosho RCP and normal RCP? Ensonic RCP Tracks 10 2010.02.19 12:02 PM
FS: Kyosho Mini-Z Monster Parts mikOll Mini-Z Marketplace 4 2007.04.17 01:03 AM
Gil Losi, Jr. Moves To Kyosho America arch2b Mini-ZRacer.com Announcements 0 2007.03.21 04:22 PM
