Old 2018.03.28, 08:44 PM   #1
yellowdog
Rear tire thickness w/o traction
Hi,
I am a 2wd driver using PN KS super soft for rear tire. Would like to ask how thick will the rear tire lose traction? My rear tire still have 24mm diameter but lost traction at tail and resume normal after changing new one with around 25.5mm diameter.
Firstly, I thought the car spins because the spur gear (53t)of ball diff touch ground but checked that the spur still have ~1mm to the ground. That seems not a problem. So would like to ask experienced driver how long can the rear tire be used.
Thanks.
yellowdog is offline   Reply With Quote
Old 2018.03.29, 01:10 AM   #2
TeeSquared
Redline
Is the body rubbing a little when the suspension is compressed? I had this issue with all of my cars that ran the McLaren 12C body. Solution was to remove material from the rear diffuser such that the chassis touches the ground before the body does.
Old 2018.03.29, 02:18 AM   #3
yellowdog
I think not but I will have a check. It also happen even I run without body. Thanks.
Old 2018.03.29, 05:52 AM   #4
You haven't mentioned the surface you are running on so I will assume RCP.
The first thing I would do would be to try a different tire combination like kyosho 17-20 rears and Kyosho 2-30 fronts. If this cures your issue then you are home free. If it doesn't cure the concern then look to the diff adjustment or action.
It would be helpful if you posted a complete breakdown of what you are running so that all aspects can be factored in.
Old 2018.03.29, 10:49 AM   #5
yellowdog
I am running RCP with front PN KS soft and rear SS. The combination is fine when rear tire is new but begin to lose traction when the rear tire worn out. So I guess the rear tire becomes thin and lose traction
Old 2018.03.29, 11:30 AM   #6
To each there own. What method are you using to adhere the tire to the wheel? As the tire wears it will peel up along the edges of wheel when cornering. This will effect how loose the car gets.
Tags
FS: rear tire gate for overland arch2b Miscellaneous Discussion 7 2003.07.22 08:09 PM
Ferrari 360 Modena rear tire rub? what_apex? Setups 1 2003.01.19 03:51 PM
Traction Roll--- ACK! Vi5i Setups 19 2002.10.22 06:27 PM
Kyosho's new semi-wide rear tire herman Parts and Hop-ups 2 2001.11.15 02:34 AM
kyosho's semi wide rear tire herman Beginner Questions 0 2001.11.13 01:59 AM
