Old 2010.02.22, 11:32 AM   #1
Guinness
Differences between Receiver RA-19 and RA-22?
Can anyone please tell me the difference between the RA-19 and the RA-22?
Thanks.
Guinness is offline   Reply With Quote
Old 2010.09.17, 11:20 AM   #2
Guinness
Anyone know? Also, what about the RA-18?
Trying to figure out which board I should get to convert an MR-015 to 2.4ghz
Old 2010.09.17, 12:06 PM   #3
Sinister_Y
Sinister_Y's Avatar
Which controller are you using? If you using the new KO Eurus with the RF902 module, then for sure, get the RA-22 board. If you're not, the RA-18 board is fine. If you do install this the RA-22 into a MR-02/15, you'll have to change up the servo motor to the original one (cored, i.e. not coreless).
The difference is that the RA-22 board and it's corresponding transmitter module are faster than the RA-18/KT-18/RF901 module and that you're able to program the reverse delay and use a gyro. The RA-18 board has a inheritant delay between brake and reverse.
Ask me for more details tomorrow at the shop when you come to practice. BTW, I have both boards in stock.
Mini-Car Club of Canada (MC3)
Premier Mini-Z Race Track & dNaNo Sales in Toronto, ON Canada
www minicarclubofcanada com
Sinister_Y is offline   Reply With Quote
Old 2010.09.17, 12:32 PM   #4
Guinness
Thanks Shawn. I did notice the servo motors were different but didn't realize about the delay. I'm using a KT-18 and since it's going in a MR-015 which will only be used around the house and not for any racing, i guess the RA-18 will be fine.
When I come by tomorrow, i'll take a look at one
Old 2013.10.19, 02:09 PM   #5
does anyone know when the change from reverse delay RA-18 to RA-22 chassis set was done? looking at purchasing a 599xx chassis set for my son but don't want to bother with the 2.4 board with reverse delay as he will be using reverse a lot.
Old 2013.10.19, 06:08 PM   #6
ChiMiniRc
I can say that all the mr-02ex boards are programmable just like the mr-03. And if you don't have the cable, I can set it up for you with the lowest reverse delay settings as well as the wide throttle neutral setting. (Hin't hint, I have an mr-02ex chassis for sale and have 599xx bodies as well)
ChiMiniRc is offline   Reply With Quote
Old 2013.10.19, 08:22 PM   #7
KWT
I bought the USB ICS cable and can bring it with me next weekend if you want me to program it.
