Old 2007.05.07, 05:07 PM   #1
rharris
that Orange car is fast..
rharris's Avatar
PN Racing NASCAR Motor Mount
I guess this should go in the MR015 section, but you can use this on a MR02 chassie too so here it is.
New Nascar 102mm Pro Motor Mount 2007-05-04
News Summary:
If go fast, turn left oval racing is what you are after then PN Racing has just the motor mount for you.
Designed with oval racing in mind the 102mm Motor Mount places the drive gear on the left side. This helps put more weight on the inside of the turn to help increase traction and consistent handling on the high speed oval track.
The kit comes standard with two center posts to allow for a top damper, side damper or disk damper systems. The longer post is used to connect a center dampening spring. The shorter post is used with disk dampers systems.
News Content:
When connecting the motor please remember to reverse the motor leads. With the motor pinion on the left side the leads must be reversed for the pinion to spin in the correct direction. Connect the positive motor lead to the negative side of the PCB. Connect the negative motor lead to the positive side of the PCB.
When connecting the MM T-bar remember to use the forward mounting holes.
Designed for use with the following products:
- MR02 Side Damper Plate (Model No MR2065)
- MR02 MM Graphite T-bar Sets (Model No MR2023)
- MR02 Multi Length Disk Damper Set (Model No MR2060)
Key features:
- Lighter then stock
- Lower center of gravity then stock
- Designed with multiple damper systems in mind. Top damper spring, side damper springs or disk damper systems
- Available in Orange, Silver, and Blue
- Shifts more weight to the left side.
FS: PN Racing MR-02 2.4ghz + KT-18 RTR ekim628 Mini-Z Marketplace 12 2008.09.27 10:29 PM
FS/T: KYOSHO / PN RACING PARTS MR01/F1/Overland kryten Mini-Z Marketplace 4 2008.02.19 05:09 PM
New Nascar 102mm Pro Motor Mount PN Racing. Ton Parts and Hop-ups 0 2007.05.04 04:59 AM
Mini-z NASCAR Series Tim Johnson Kyosho 137 2007.03.10 02:38 PM
Anyone in IL interested in racing Mini z Nascar? rock6922 Autoscales, Bodies, Cars and Drivers 2 2002.01.21 08:37 AM
