Old 2019.02.28, 09:17 PM   #1
interesting servo info for you all....
Hi!
In the process of wiring a scratch build FWD I somehow got something wrong in the servo and sent the servo into conniptions.
By doing that I found out two things:
1. the Chinese plastic is even more fragile than normal and you can strip servo gears easily.
2. The servo gear that connects to the pot gear/servo arm is exactly the same cut/pitch as the 4th gear from the MR03. That means you can replace the unit with the metal aftermarket gear from the various companies that produce it.
Old 2019.03.01, 12:45 AM   #2
HaCo
02-Racer
HaCo's Avatar
Thanks for sharing.
HaCo is offline   Reply With Quote
ASF servo lock blt456 Mini-Z Racer MR-02 2 2009.05.23 10:13 PM
incompatibility receiver servo? rivaldo 2.4GHz ASF System (Auto Selected Frequency) 0 2009.04.19 09:57 AM
InZane P28 1/28 racing chassis from Reflex Racing! ruf Mini-Z Racer MR-02 56 2009.04.10 01:25 AM
servo compare of MR02 and OL PAULANGELO Miscellaneous Discussion 3 2004.01.12 01:11 PM
mini-z hybrid with micro electronics bdreeft Mini-Z Science 8 2003.06.18 04:06 PM
