Enjoy the thrill of battle with Palmtop Formula Car Racers
The Mini-Z Formula Car offers performance it belies its size. Use real driving techniques to maximize its race winning potential. A sophisticated high-density chassis puts the Mini-Z Formula Car in a class of its own. Run your own Formula Car series races with up to 6 cars racing at the same time! Delivered fully factory-assembled for fast fun. Quality engineered to meet the exclusive formal licensing standards of the world’s leading race teams.
Enlarged suspension system using king pins and coil springs for sharp but consistent control characteristics. Newly developed servo demonstrates fine handling response and easy disassembly and maintenance. Body structure is integrated for mid-chassis centering and allows for higher levels of control and response. Compact size servo saver provides indispensable servo protection from unexpected knocks and crashes.
External coil spring and twin-arm swinging system delivers excellent suspension tracking. Consistent traction allows aggressive driving.
4 different sizes of pinion gears are included with each set. Choose the right pinion gear to suit your track conditions. Bevel-type differential gear gives the stability needed for fast cornering.
Electronics Configurations
Standard AM radio system combines the receiver and speed control for efficient running and precise control. New RA-4B FETs allow better power handling.
The latest ASF 2.4GHz unit delivers the amazing experience of micro motor racing. Fastest signal processing speed available produces a truly direct control feel. FET with double the capacity of previous models also features LED that indicates power status when power is switched ON. The ASF 2.4GHz unit is also fitted with I.C.S. that allows servo and motor control settings through a computer.
Special Editions
SP Limited Edition
Formula machine packed with special features for extra speed and without transmitter. The one and only palmtop racing machine with both performance and ultra-real styling.
With a chassis only 182mm long, who could believe an advanced R/C Formula-1 racer like this could fit on the palm of your hand! Featuring a high-frequency FET speed controller that delivers powerful yet sensitive traction control and brake function, as well as providing precise steering response that allows drivers to show all their skills. Only four AAA-size alkaline batteries are needed to provide about 1 hour run time and a huge range of optional parts and Officially-licensed bodies and color schemes bring out the excitement of real F-1 racing. The SP Limited version also includes special racing parts for drivers on a quest for ever more speed. Packaged without transmitter, the SP Limited makes an ideal 2nd or 3rd machine for your high-performance lineup.
Tenth Anniversary SP Limited ASF 2.4GHz Edition
Specially equipped Formula Car with 2.4GHz control unit! Speed and realism in a palmtop Formula Racer!
The remarkable 2.4GHz control unit is pre-installed on this palmtop-sized Formula racing machine which is just 182mm in length. Previously only available on the Formula model as an option, the 2.4GHz unit not only eliminates the stress of managing frequency bands but also adds performance to please drivers looking for even more speed. To make it even more economical, this kit is packaged without transmitter so you can use your existing ASF 2.4GHz transmitter, making it ideal as a 2nd or 3rd addition to your MINI-Z collection. Add your favorite F-1 team's body and start living your own scale Formula racing dream!
SP Limited ASF 2.4GHz Special Features
Full ball bearing specifications.
Xspeed V motor
Red anodized aluminum motor mount
Red anodized ball differential
Black chassis with gold plated terminals
High grip tires (F/30°, R/20°)
F-1 STOCK PARTS KITS
No. MF12 MAIN CHASSIS SET ASF
No. MF13 CHASSIS SMALL PARTS SET ASF
No. MF14 R/C/ UNIT SET 2.4GHZ RA-18F
Top picture property of Herman C., used on this page with permission.
Other images and text are property of Kyosho Corporation, and used on this page only for informational purposes.
