Old 2008.04.19, 12:49 AM   #1
Flashsp-2
motor guru
Flashsp-2's Avatar
FS mod AD band Pan car
SOLD SOLD SOLD
Contact: ahdmullins @ gmail.com
Description: AD band pan car, mods, see below. Price is $230 shipped in US, $240 shipped overseas.
It has an AD band FM board and transmitter module. AD band is a step above normal AM mini-z, the response is faster, the signal is clearer, and the power deliver is much smoother. This board has been hardwired to the chassis to eliminate power loss and reduce the chance of static shut down, which is something this car has never experienced. The board also has stacked FETs, 6 total SP8M4, which are the best on the market, in my opinion. The ball diff has been upgraded with PN 64 pitch gears, as well as a 5 ball ceramic set-up. The plates have also been wet sanded to ensure flatness and smoothness. This diff is outstanding, and has to be felt to believe how smooth it is. The damper system has also been wet sanded with 3000 grit to ensure smooth operation. The damper system has firm springs on top and medium springs on the bottom to provide neutral handling in and out of corners. The motor is a stock armature in a PN can, which is a great balance of speed and acceleration. Below is a list of all the hop-ups on the car.
Kyosho
SP gold terminal smoked chassis
SP delrin servo gears
AD band and module
AD band chassis cover
20 degree radial tires, 75% new
Enzo +3 offset rear wheels
Atomic
LCG motor mount
Bearings
Titanium DDS 98mm
DDS springs (firm, medium)
V1 ball diff (PN 64p 52 tooth spur, 13 tooth pinion, Kyosho o-ring, ATM ceramic balls)
Orange/blue front spring set
Delrin spring posts
Plastic 1.5 degree knuckles
PN Racing
Pan car body (unpainted, wing missing, used condition)
Ultra ball bearing motor can
Plastic 3 degree knuckles (extra)
Stainless kingpins
8 degree rear radials, like new
Mesh +3 offset front wheels
3Racing
Soft H-plate
Team Scream Racing
Matched 900mAh cells
Extras
Kyosho McLaren body (about 7 out of 10 condition), wheels/clip
Miscellaneous 48p gears for ball diff
Kyosho o-ring for ball diff
CAT-5 antenna mod
I'm sure that I am missing a few things. This car is in outstanding condition, as I always take car of my cars. It runs very flat and has great power delivery, balance, and signal reception. This car is essentially as hopped-up as it gets, and there aren't really any stock parts left, with the exception of the servo parts. If you have any questions let me know. Don't pass up an opportunity to own a great car like this. Price is negotiable, but don't try to lowball me with something ridiculous. And no, I won't part it out, unless somebody wants the McL separately.
Old 2008.04.19, 06:36 PM   #2
Flashsp-2
motor guru
Flashsp-2's Avatar
Sale pending
Old 2008.04.19, 10:43 PM   #3
Flashsp-2
motor guru
Flashsp-2's Avatar
Item is sold
FS: MA010 mod car w/Nelly, handwound motor Flashsp-2 Mini-Z Marketplace 5 2007.12.12 06:08 PM
throttle adjustment on the car? Zephyr von Bobo iWaver 9 2006.05.11 07:07 PM
Car not moving forward or reverse newm5 Mini-Z Science 8 2005.12.16 12:40 AM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 08:23 PM
