Old 2005.07.01, 02:16 PM   #1
lio
My GPM Mini-T
Here's my latest project. A Mini-T built from GPM parts alone. I have yet to add the electronics (just the Li battery in the pic). Some Team Losi parts may be needed to complete the project.
Thanks for looking.
lio is offline   Reply With Quote
Old 2005.07.01, 02:42 PM   #2
TNB
Pet Human
TNB's Avatar
Did you get any Kyosho Mini-Zs yet? If so, where are the photos???
Gallery TNB
Old 2005.07.01, 09:08 PM   #3
lio
Actually I collect Mini-Zs but most of them in my collection are just stock so there's nothing very interesting to show
Old 2005.07.03, 05:07 PM   #4
Bad Company
That is one pretty chassis you have there, makes me want to start a new project. Mind if I ask how much invested so far?
Bad Company is offline   Reply With Quote
Old 2005.07.03, 06:02 PM   #5
Stoovey
Dude, that rocks! Makes me want to follow suit. Looks great! I'd be interested in a full spec sheet details what parts you needed, and a cost breakdown. What else is needed, or is it ready to roll?
Stoovey is offline   Reply With Quote
Old 2005.07.03, 07:08 PM   #6
mini-z racing
Team Losi
Send a message via AIM to mini-z racing
That looks nice, you should get a alluminum chassie for it
Had a great time at RCX
www.jakeafiedmotors com
www putnampro.com
www racingcity com
mini-z racing is offline   Reply With Quote
Old 2005.07.04, 02:03 AM   #7
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Erm.. not....
CF is superior to alloy in strength and weight.. plus it looks better, if lio wanted an alloy chassis, he would have fitted one
Nice Mini-T there lio. Do you ever run it at all?
Mondo
__________
Old 2005.07.04, 09:24 AM   #8
lio
Hi all,
Thanks for the compliments Actually I copied the idea from a local GPM shop where they displayed many RC models fully hopped up with GPM parts. The Mini-T looked the best so I decided to assemble my own.
The complete list of GPM parts used in the chassis is as below. All are silver alloy except where noted.
SMT003F/L Front Bumper Large Size (80mm Wide) 1 Piece
SMT003R Rear Motor Guard Protector 1 Piece
SMT008 Front Lower Pivot Block Set 1 Piece
SMT010 Rear Lower Pivot Block Set 1 Piece
SMT012A Front Upper Cap For Steering 1 Piece
SMT012B Front Lower Brace For Steering 1 Piece
SMT013 Rear Gear Box 1 Pair
SMT014 Servo Upper Kick Plate 1 Piece
SMT019 Front Steering C-Hub With Steel Pins 1 Pair
SMT021/T Front Knuckle Arm + Titanium Wheel Shaft 1 Pair
SMT022 Rear Hub 1 Pair
SMT028 Front Damper Plate 1 Piece
SMT030 Rear Damper Mount 1 Set
SMT032 Main Gear Cover 1 Piece
SMT0527F Front 3D Sinkage Rims (5 Poles) 1 Pair
SMT0527R Rear 3D Dented Rims (5 Poles) 1 Pair
SMT055 Front Lower Arm 1 Pair
SMT056 Rear Lower Arm 1 Pair
SMT201F Front Body Post 1 Pair
SMT355 Front Adjustable Spring Damper (55mm) 1 Pair
SMT360 Rear Adjustable Spring Damper (60mm) 1 Pair
SMTBEARING Bearing Full Set (4X8X3) 8 Pieces
GSMT1016FS/B Graphite Chassis (w Servo Mount/Saver and Antenna Mount) 1 Set
GSMT009 Graphite Front + Rear Lower Arm Lock Mount Plate 2 Pieces
TDSMT100A/II Titanium + Delrin Ball Differential With Bearing 1 Set
TSMT242 Titanium Rear Universal Swing Shaft (42mm) 1 Pair
SMT048 Front Steering Assembly 3 Pieces With Graphite Plate 1 Set
SMT018 Motor Heat Sink Plate 1 Piece
TSMT160 Titanium Complete Tie Rod With Ball Ends 7 Pieces
GSMT049 Graphite Steering Plate With Screws 1 Piece
The tires are from Pro-line instead.
The above costed me about USD330 in total. A few original Mini-T parts (mainly for the gear) are also needed to complete the chassis.
There're no instructions for the GPM parts so I made reference to a "real" Mini-T for assembly. The exploded view diagram from the kit is useful.
I have yet to add the electronics (other than the 2 cell LiPoly already installed) so I have not run the car yet. I hope some good electronics could compensate for the heavy weight, though the car is really meant for the look rather than speed. Any recommendations for the electronics are most welcome !
lio
Old 2005.07.04, 05:13 PM   #9
Mondo
Mondo's Avatar
Lio,
If you are concerned about the weight, a good brushless motor would work well.
I recommend a Mamba25 6800 system.
If you're looking for a good site on Micros, try Mini-ZRacer.com's sister site, YourMicro.com
There is lots of information on Mini-T's and other Micro scale RCs on this site and you will find lots of information on brushless systems
Mondo
__________
Old 2005.07.04, 05:49 PM   #10
mini-z racing
Team Losi
Go with brushless, its very fast. There worth the money you will spend the same or a little more if you went with brushed motors.
www putnampro.com
www racingcity com
Old 2005.07.08, 11:17 PM   #11
lio
Thanks a lot for the suggestions for motors and website!
Old 2005.07.09, 02:05 AM   #12
Stoovey
Thanks for posting the list of components!
Old 2005.08.20, 02:28 AM   #13
lio
Hi,
I have finally completed the project with my very limited spare time. Below is the final recipe for my GPM Mini-T, including electronics. I have refined the look of the chassis using some non-GPM parts such that the car is only silver and black (except the electronics). A photo is attached.
GPM Parts
Graphite Front + Rear Lower Arm Lock Mount Plate 2 Pieces GSMT009
Graphite Main Chassis 1 Set GSMT1016FS/B
Alloy Front Bumper Large Size (80mm Wide) 1 Piece SMT003F/L
Alloy Rear Motor Guard Protector 1 Piece SMT003R
Alloy Front Lower Pivot Block Set 1 Piece SMT008
Alloy Rear Lower Pivot Block Set 1 Piece SMT010
Alloy Front Upper Cap For Steering 1 Piece SMT012A
Alloy Front Lower Brace For Steering 1 Piece SMT012B
Alloy Rear Gear Box 1 Pair SMT013
Alloy Servo Upper Kick Plate 1 Piece SMT014
Alloy Main Gear Adapter 2 Pieces SMT015
Alloy Motor Heat Sink Plate 1 Piece SMT018
Alloy Front Steering C-Hub With Steel Pins 1 Pair SMT019
Alloy Front Knuckle Arm + Titanium Wheel Shaft 1 Pair SMT021/T
Alloy Rear Hub 1 Pair SMT022
Alloy Front Damper Plate 1 Piece SMT028
Alloy Rear Damper Mount 1 Set SMT030
Alloy Front Steering Assembly 3 Pieces With Graphite Plate 1 Set SMT048
Alloy Front Lower Arm 1 Pair SMT055
Alloy Rear Lower Arm 1 Pair SMT056
Alloy Front Body Post 1 Pair SMT201F
Alloy Front Adjustable Spring Damper (55mm) 1 Pair SMT355
Alloy Rear Adjustable Spring Damper (60mm) 1 Pair SMT360
Titanium Motor Gear (13,14,15T) with Hex Wrench 1 Set TSMT0131415T
Titanium Main Gear (61T) 1 Piece TSMT061T
Titanium Complete Hinge Pins 5 Pairs TSMT101
Titanium Rear Universal Swing Shaft (42mm) 1 Pair TSMT242
Titanium + Delrin Ball Differential With Bearing 1 Set TDSMT100A/II
Bearing Full Set (4X8X3) 8 Pieces SMTBEARING
Team Losi Parts
Camber and Steering Link Set LOSB1031
Wheel Nuts & Drive Pins LOSB1045
Rod End Set (14) LOSB1049
Transmission Ball Bearing Set (7) LOSB1060
Transmission Shaft Set LOSB1062
Differential Gear Bag LOSB1066
Slipper Hardware Set LOSB1064
Dual Disk Slipper Conversion Kit: Mini-T LOSB1131
Titan Turnbuckle Set (6): Mini-T LOSB1230
Wheels and Tires
RPM "Spider" 1/18th Scale Truck Wheels Front for the Losi Mini-T Chrome 73203
RPM "Spider" 1/18th Scale Truck Wheels Rear for the Losi Mini-T Chrome 73223
2 X Pro-line Dirt Hawg 1:18 Tire (Fits 1:18 Front or Rear Wheel) 1116-00
Electronics
Hitec Might Micro Servo (Ball Bearing, Metal Gear) (Fut-J) HS-85MG
HPI Racing Micro Servo Saver Set (Micro RS4) 73435
Novak Spy Micro Reversible ESC
Dynamite 1900mAh 7.4V LiPo for Mini-T DYN1421
Peak Racing Raider Mini-T Modified Motor PEK1406
2 X Deans Micro Plug 2NB 1225
Futaba Megatech 3PM-FM Transmitter (76) (75.710 MHz)
Miscellaneous
Dubro Racing Antenna Tube with Cap (Black) 2340
BRP Mini-T Mini Heavy Hitter body clips
Trinity Mini-T Front Spring Set (Soft, Medium, Hard) TRI34068
Trinity Mini-T Rear Spring Set (Soft, Medium, Hard) TRI34069
4 X Lunsford Mini-T Titanium Ball Studs 7181
Lunsford Mini-T Differential Cover & Fat Boy Motor Screw Kit 7949
For the motor, I've in fact bought the Castle Creations brushless system for the car. The green motor looks awesome by itself, but does not match the colour of the chassis so I finally decided to use the Peak Racing motor instead. It's slower but is good enough for my need (running indoor in a small living room).
I am now looking for a custom painted body to fit the car to really finish the project.
Thanks for looking
Old 2005.10.01, 12:33 AM   #14
lio
Hi,
Now I have attached a Baja body The holes have not yet been drilled.
Credit of the custom paint work goes to Aaron Kilian of RCXTC [http://www.rcxtc.com/]. I sent Aaron the pic of the chassis and he got me this desgin. Both the look and workmanship are excellent in my opinion. I am so satisfied that I have ordered another body from him for my XRay M18.
Thanks for looking!
Old 2005.10.02, 09:48 PM   #15
SonicFury
Sun Speed and Sin
SonicFury's Avatar
Send a message via AIM to SonicFury Send a message via MSN to SonicFury
That's pretty dang awesome. All you need now is a wheelie bar and SOME DIRT ON IT
Micro Madness The Movie
SonicFury is offline   Reply With Quote
GPM Overland parts arrived Mondo Mini-Z Overland MV-01 10 2003.01.21 10:50 AM
GPM parts lookinco Miscellaneous Discussion 0 2003.01.07 03:10 AM
