2007.11.07, 08:52 PM
Post images of your Monster
I Realized nearly every model but the monster had their own picture thread, so here it is...
I'll start it off with some up to date pics of my most recent setup:
2007.11.08, 04:16 PM
Alot of that stuff looks familiar lol
2008.01.11, 10:19 PM
Honda Insight Racer!
Well, now it's mine! LOL!
I plan on rebuilding it to match my Miss America Micro-T. So far, I've ordered a clear skeleton chassis set, allloy five star wheels which match perfectly the ones on my Micro, and an alloy rear gear box set in blue. I plan on removing the blue color on the wheels as my Micro-T's got chromed ones. I've heard Easy Off oven cleaner is best for removing the anodized finish? Question is, will it tarnish the aluminum finish, and how would I polish it back up?
Second question, is the skeleton chassis kit easy to do on the Monster? So far, I've done it on AWD, MR01, MR15, MR02, and the Lite. Monster any easier?
2008.01.14, 11:39 AM
nice mzm!i recently installed the skeleton chassis on my overland, i know theyre abit different but you have to make sure the servo and pot wires go in right- theres a slot and i found it tricky to get them in there. i ended up filling the slot bigger. also the power switch and power wires are abit fidly, but after a few minutes they go together ok.
now with a new soldering iron
2008.01.16, 06:08 PM
Thought i'd add a couple of pics of my monster
I have a gpm rear g/box on order to finish her off.
Reason: New pics added
2008.01.16, 06:09 PM
forgot one
Keep forgetting i have two MZM's lol
[IMG] [/IMG]
Reason: added new pic
2008.01.20, 07:36 PM
microracer's is out of the parts I ordered and I didn't have cash to send theme so I'm out of luck on those parts. I think I just might go all Kyosho on this one as Kyosho parts seem to be easier to find than GPM's alloy. Plus on the truck, the alloy makes it heavy. I usually do alloy on the cars, but the alloy is smaller and seem's lighter. I think on the truck the parts are bigger and heavier. I could be wrong, but I still think going all Kyosho would be better. All clear chassis with chrome bit's, blue screws, and gun-metal alloy.
2008.01.21, 10:54 AM
I had the same problem trying to order front/rear gear casings for mine.
I ordered from hong kong in the end and they only had the front one in stock(rear is on order too) and they are 4x the price of the overland ones
2008.02.05, 03:59 PM
Both my monsters have now changed a bit!
Specs are (All alloy is GPM)
Alloy front servo/gear case,Blue
Alloy steering assy
Alloy 1* tie bar
Alloy 1*knuckles
Alloy front shock mount
Alloy rear shock mount
Alloy rear gearbox arm mount
Alloy rear gear cover
Alloy motor cap/heatsink
Alloy wheeliebar
Alloy front/rear lower arms
Alloy front bumper
Kyosho oil filled shocks
Full ball bearing kit
Alloy 5 spoke wheels(blue and black)
Alloy wheel nuts
I have a rear gearbox on order,and an alloy ball diff and titanium main gear ready for when it gets here.
2008.02.05, 09:43 PM
Hi, i'm fat
Very Nice Marc...
This hobby takes away my lunch money
My Gallery
Reason: vbnbvb
2008.02.06, 02:12 AM
iTomCash
Spot the difference... I like a challenge!
I wanted a blue servo casing, but they only had silver... Where did you get that from?
2008.02.06, 04:24 AM
I got it from a jap shop,tho i'm still waiting for the rear gear casing in blue.
2008.02.06, 04:39 AM
iTomCash
Which shop mate?
2008.03.05, 11:13 AM
MiniZMonster
Hi,
Here is my ultimate Mini Z Monster Truck
And it might be for sale for the right price...
Cost Of Kit
1 x KYOSHO MINI-Z MONSTER KIT IN BLUE AND YELLOW £100.00
1 x ATOMIC MODS FAT BOY MODIFIED MOTOR £ 20.00
4 x SI4562DY MOSFET Chip £ 8.00
10 x GPM LOW FRICTION BEARINGS £ 8.50
1 x KYOSHO SKELETON CHASSIS SET BLUE £ 8.00
12 x KYOSHO 4.8mm SILVER MILLED BALLS £ 11.50
1 x 3 RACING LIGHT SYSTEM £ 8.00
2 x GPM TITANIUM HINGE PINS £ 3.00
2 x GPM TITANIUM KING PINS £ 2.50
4 x GPM FRONT/REAR RUBBER RAD TYRES AND INSERTS 40DEG (ROAD) £ 8.50
4 x GPM ALUMINUM BLUE ADJUSTABLE SPRING DAMPER SET £ 16.00
4 x GPM ALUMINUM BLUE FRONT/REAR 3D DENTED VACUUM RIMS (STAR) £ 15.00
1 x GPM ALUMINUM BLUE DELRIN BALL DIFFERENTIAL TITANIUM SHAFT -1/8 £ 12.00
1 x GPM ALUMINUM BLUE MAIN GEAR COVER £ 7.00
1 x GPM ALUMINUM BLUE STEERING ASSEMBLY £ 6.00
1 x GPM ALUMINUM BLUE FRONT KNUCKLE ARM SET 1DEG (2PC) £ 7.50
1 x GPM ALUMINUM BLUE TIE ROD +1DEG (1PC) £ 7.50
1 x GPM ALUMINUM BLUE FRONT DAMPER MOUNT £ 8.00
1 x GPM ALUMINUM BLUE DAMPER MOUNT £ 7.00
1 x GPM ALUMINUM BLUE BATTERY MOUNT WITH HEAT SINK £ 6.50
1 x GMP ALUMINUM BLUE GEAR BOX (FRONT) £ 25.50
1 x GMP ALUMINUM BLUE GEAR BOX (REAR) £ 34.00
5 x GPM ALUMINUM BLUE LOCKING NUTS 2MM £ 3.50
1 x GPM ALUMINUM BLUE REAR BUMPER £ 8.00
1 x GPM ALUMINUM BLUE REAR MOTOR CAP WITH HEAT SINK £ 5.50
1 x GPM ALUMINUM BLUE FRONT LOWER ARM £ 4.00
1 x GPM ALUMINUM BLUE REAR LOWER ARM £ 4.00
1 x GPM ALUMINUM BLUE FRONT BUMPER £ 6.00
Total £361.00
Read about it on my website:
http://myweb.tiscali.co.uk/rchobbies/minizmonster.htm
email me at rchobbies@tiscali.co.uk
Damian.
2008.03.06, 04:42 PM
UK, Stafford Mini Z Racer
Nice monsters guys, i especially like yours Niamad.
Heres mine...
Mustang
Jeep CJ5
Racing a Limited Edition Lamborghini Murcielago.
No1 of only 3000 made.
'There can be only one'
