Old 2007.09.27, 07:56 PM   #1
soulstice
soulstice's Avatar
Cleaning RCP
A lot of my track has been in a garage that did not do a good job of keeping outside dust and dirt out. I was wondering what is the best way to clean my track without damaging it.
Can I just run a water hose on it and then let it dry?
Thanks in advance.
My Lego Habit: FoundryDX
Old 2007.09.27, 09:00 PM   #2
Spoon
DCGTG FET Guy
Spoon's Avatar
Thanks in advance.
I picked up a sponge mop from Lowes and used that. It worked pretty well. You might be able to just hose it off but I wouldn't let it dry in the sun. The mop method wasn't too bad and I got a LOT of dirt off of my track that way.
I would start with a light vacuuming, then the mopping and it should dry pretty quickly indoors with a fan on it.
These shots will give you an idea of how much track I had to clean...I should have taken a picture of the mop water...GROSS.
http://mini-zracer.com/mini-zgallery...y.php?cat=1067
Old 2007.09.27, 09:04 PM   #3
byebye
byebye's Avatar
Hose it off and let us know. I know that I just vacuum mine and over time I get all the RCP dust as well as the dust dust.
Kris
Old 2007.09.27, 09:27 PM   #4
lfisminiz
lfisminiz's Avatar
I use the brush part of my old vac. IF you use a beater type vac end...dont let it in 1 spot to long, keep it moving.
Old 2007.09.27, 10:31 PM   #5
RCPMini-z
rcptracks.com
All the above sounds good.
Don't hose off the track. If you need to get it wet to remove dirt, than a lightly dampened mop or rag will do just fine.
The side rails can be scrubed with soap and water if needed.
RCP West Coast Challenge at RCX RCPMini-z Tracks and GTGs 90 2008.06.28 12:32 PM
RCP Adjustable Bank Turn RCPMini-z Race Tracks, Track Layouts, Track Accessories 43 2005.05.05 12:44 AM
RCP cleaning ? Roger RCP Support Forum 12 2005.03.23 06:27 PM
Cleaning the RCP Track mats. What works and doesn't? francis_Z Tracks and GTGs 7 2004.05.17 02:37 AM
