Old 2011.04.22, 02:55 AM   #1
Racer-HH
Racer-HH's Avatar
High Response Mode with Mini-Z ASF
Hi,
just wondering what will change, if I switch from "normal" to "high" mode. I was in normal mode the last 6 years and yesterday I tried high for the first time but I did not feel any difference with MR-03 or dnano?
Any thoughts?
Racer
[ my TX: EX-6 ]
Old 2011.04.25, 12:59 PM   #2
KO PROPO Staff
Racer-
I'm assuming that you are using the EX-10 Helios so this would be the difference in response modes.
Normal - 2 or 3 channel setting will give you 16.0ms response
High - 3 channel setting (High Response Mode) gives 11.0ms response
High - 2 channel setting (Advanced Response Mode) give 8.0ms response
Old 2011.04.25, 01:14 PM   #3
Out of curiosity, what are the numbers for the EX-1 UR when switching between modes? Thanks!
Old 2011.04.25, 02:16 PM   #4
KO PROPO Staff
Response is the same for the EX-1 UR number wise, but the feeling is different.
Old 2011.04.25, 10:56 PM   #5
hmm... i thought you couldn't use the high response mode with the asf...
guess i was wrong... so has anybody else felt the difference?
Old 2011.04.27, 05:42 AM   #6
Racer-HH
Racer-HH's Avatar
Originally Posted by KO PROPO Staff View Post
Racer-
Thanks. And yes, you are right in your assumption. I meant advanced response mode in comparison to normal.
Right now - after switching for several runs - I still feel no real difference, but maybe I am just too old for this micro second speed split ...
[ my TX: EX-6 ]
Old 2011.04.27, 09:29 AM   #7
In quick left-right transitions I have noticed the difference before, which is why I was curious what the actual (numerical) lag time was. Thank you for answering that.
Now what's this about the EX-1UR and the EX-10 Helios feeling different despite same lag time? I would expect that for equal transmitter settings, the two transmitters should produce equal results out of the car.
Old 2011.04.27, 10:39 AM   #8
chad508
chad508's Avatar
i was under the impression that the ex1 had the newer software same as the eurus.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Futaba 1/20 Scale Indy Cars Mondo Mini RC 54 2006.05.12 09:35 PM
Originator of the 5 Cell Mini Z with BIG BAD JOHNSON NOMOTORLIMIT Miscellaneous Discussion 8 2002.12.07 11:23 PM
Noble Pieze Prize For Mini Z Breakthroughs NOMOTORLIMIT Miscellaneous Discussion 0 2002.12.07 01:55 PM
