Old 2013.09.21, 10:44 AM   #1
Mini-Z Brushless Motor Specs
Kyosho
Kyosho Mini-Z Brushless X-Speed VE Motor
Part Number MZ504
Motor that comes with brushless motor and normal (8,500 KV)
*Please note that this ships standard with MA-020 VE PRO SP and the motor appears to have been recolored to be entirely red. Currently the can is red and the plastic sheath or case is black.
Kyosho Mini-Z Brushless ECO VE Motor
Part Number MZW501
eco-tune motor of blue color from (5,600 KV)...Eco-tune the motor a little bit faster than normal motor, slower than specification Xspeed V motor.
Kyosho Mini-Z Brushless X-Speed VE PRO Motor
Part Number MZW503
12000KV
XSPEED 41 Brushless Motor
Part Number MZ606
(4100KV)
SPEED HOUSE XSPEED 85 Brushless Motor
Part Number
(8500KV)
SPEED HOUSE XSPEED 56 Brushless Motor
Part Number
(5600KV)
Old 2014.03.01, 04:17 PM   #2
PN Racing
PN Racing Mini-Z brushless Motor 3500kv
Part Number 140035
PNWC 2016 2WDStock class rules FIXED gear ratio
Kyosho 44T Spur Gear and 9T Pinion (4.88)
64P 53T Spur Gear and 11T Pinion (4.81)
126P 106T Spur Gear and 22T Pinion (4.81)
New V2 Version
Changeable armature
New design air vent get more cooling
High Temperature wire
15mm diameter motor can, same as normal brushed 130 motor. Fits in all Kyosho, PN, and aftermarket motor mounts.
Fits in all Mini-Z chassis AWD, F1, MR02 and MR03.
Much more torque and acceleration than others VE motor.
No loading RPM 22000 on 4.8V, amp draw only 0.28A
Four mounting holes to allow different angle of motor terminals.
Eight venting holes prevent heat buildup.
Can and endbell ball bearing from Japan.
Recommend gear ratio 3.95 to 5.00
Connection M1 to Orange Wire, M2 to Yellow Wire, M3 to Blue Wire
Recommend wire #700122
PN Racing Mini-Z Brushless Motor 5500kv
Part Number 130055
No loading RPM 34000 on 4.8V, amp draw only 0.2A
Recommend gear ratio 4.8 to 4.00 (64P 11T-13T, 52T or 53T Spur Gear) See More
PN Racing Mini-Z V2 Brushless Motor 5500kv
Part Number 140055
New V2 Version
Changeable armature
No loading RPM 33000 on 4.8V, amp draw only 0.3A
Recommend gear ratio 4.00 to 4.80 (64P 11T or 12T Pinion, 52T or 53T Spur Gear)See More
PN Racing Mini-Z Brushless Motor 7500kv
Part Number 130075
No loading RPM 45000 on 4.8V, amp draw only 0.4A
Recommend gear ratio 4.33 to 5.30 (64P 10T or 11T Pinion, 52T or 53T Spur Gear)See More
PN Racing Mini-Z V2 Brushless Motor 7500kv
Part Number 140075
New V2 Version
Changeable armature
No loading RPM 49000 on 4.8V, amp draw only 0.45A
Recommend gear ratio 4.50 to 5.2 (64P 10T or 11T Pinion, 52T or 53T Spur Gear)See More
PN Racing Mini-Z Brushless Motor 9500Kv
Part Number 130095
PN Racing Mini-Z V2 Brushless Motor 9500kv
Part Number 140095
New V2 Version
Changeable armature
No loading RPM 63000 on 4.8V, amp draw only 0.5A
Recommend gear ratio 5.20 to 5.88 (64P 9T or 10T Pinion, 52T or 53T Spur Gear)See More
PN Racing Mini-Z Brushless Motor 11500kv
Part Number 130115
No loading RPM 80000 on 4.8V, amp draw only 1.1A
Recommend gear ratio 5.88 to 6.75 (64P 8T or 9T Pinion, 53T or 54T Spur Gear)See More
Old 2014.07.16, 01:44 PM   #3
Atomic
Atomic Mini-Z AMZ Brushless Motor 5000Kv
Part Number AMZ017-5K
Atomic Mini-Z VSX Brushless Motor 9000Kv
Part Number MO-035
Product Features:
High quality ball bearing build-in.
CNC machined end-bell compatible with AWD chassis.
The 8 screw holes design suits different angle installation and is compatible with all Atomic motor pods.
Atomic Mini-Z VMX Brushless Motor 10000Kv
Part Number MO-037
Finest throttle handling, better punchy.
HQ Ball Bearing Build-in.
8 screw holes design, suit different angle installation and compatible with all Atomic motor pods
Atomic Mini-Z VSX Brushless Motor 12000Kv
Part Number MO-036
Product Features:
Old 2014.10.01, 07:16 AM   #4
Scorpion
Scorpion Z-1410-6000KV
Part Number Z_1410_6000
Specifications
Stator Diameter 14 mm(3.15 in)
Stator Thickness 10 mm(1.57in)
No.of stator Arms 3
No.of stator Poles 2
Motor Wind 62 Turn Delta
Motor Wire 3-Strand 0.19 mm
Motor Kv 6000 RPM/Volt
NO-Load Current(IO/6V) 0.38 Amps
Motor Resistance(RM) 0.265 Ohms
Max Continuous Current 8 Amps
Max Continuous Power 57 Watts
Weight 19.8 Grams (0.59oz)
Outside Diameter 15.99 mm (0.79 in)
Shaft Diameter 1.98mm (0.08 in)
Body Length 29.8 mm (1.17 in)
Ovrall Shaft Length 37 mm (1.46in)
Weight including packaging
40g
Full Dimension
View Scorpion Z-1410-6000KV Full Dimension
Scorpion Z-1410-8500KV
Part Number Z_1410_8500
This motor is suitable for Kyosho Mini-Z racers and buggy. The Motor is is produce on the latest CNC work centres using aero grade aluminum and ultra high quality 0.2MM stator steel with High temperature resistant Magnets and enamel wires, it not only provide even higher efficiency compared to other motor in similar size of the current offering, but also higher peak power and higher torque with lower running temperature. 20.5 grams ultra light weight, it will not only increase your accelerations and top speed but also enhance the drive handling of your mini-z racers.
Specifications
No.of stator Arms 3
Motor Wind 38 Turn Delta
Motor Wire 5-Strand 0.19 mm
Motor Kv 8500 RPM/Volt
NO-Load Current(IO/7V) 2.06 Amps
Motor Resistance(RM) 0.141 Ohms
Max Continuous Current 9 Amps
Max Continuous Power 6v
Weight 20.5 Grams (0.81oz)
Outside Diameter 19.98 mm (0.79 in)
Body Length 28.5mm (1.12 in)
Ovrall Shaft Length 37.5mm (1.48in)
Scorpion Z-1410-9500KV
Part Number Z_1410_9500
Specifications
No.of stator Arms 3
Motor Wire 3-Strand 0.21 mm and 2-Strand 0.19 mm
Motor Kv 9500 RPM/Volt
NO-Load Current(IO/6V) 0.7 Amps
Max Continuous Current 10 Amps
Max Continuous Power 80 Watts
40g
Full Dimension
View Scorpion Z-1410-9500KV Full Dimension
Old 2014.10.01, 09:28 AM   #5
X-Power
BUSHLESS MOTOR 4500kv FOR MR-03VE & MRX
Part Number XP-BL-4500
Remark
Main features:
1 . A couple of models were specially designed for use with Lipo battery such that over heating problem of using other brand brushless motors with Lipo battery can be resolved.
2. There are ventilation holes in both front end & end bell of motor can such that air can flow through the motor to reduce the temperature.
3. Improved specification produces balance level of torque & top speed so as to provide a more linear acceleration for the car.
4. High quality bearing to improve the smoothness.
It comes with a 10 cm long 28AWG silicon wire (red/yellow/black)
BUSHLESS MOTOR 5000kv FOR MR-03VE & MRX
Part Number XP-BL-5000
Remark
Main features:
BUSHLESS MOTOR 6000kv FOR MR-03VE & MRX
Part Number XP-BL-6000
Remark
Main features:
BUSHLESS MOTOR 7500kv FOR MR-03VE & MRX
Part Number XP-BL-7500
Remark
Main features:
BUSHLESS MOTOR 8500kv FOR MR-03VE & MRX
Part Number XP-BL-8500
Remark
Main features:
BUSHLESS MOTOR 9500kv FOR MR-03VE & MRX
Part Number XP-BL-9500
Remark
Main features:
BUSHLESS MOTOR 11000kv FOR MR-03VE & MRX
Part Number XP-BL-11000
Remark
Main features:
BUSHLESS MOTOR 13000kv FOR MR-03VE & MRX
Part Number XP-BL-13000
Remark
Main features:
BUSHLESS MOTOR 15000kv FOR MR-03VE & MRX
Part Number XP-BL-15000
Remark
Main features:
SENSORED BRUSHLESS MOTOR 5600kv FOR X-POWER INDOOR TOURING CAR
Part Number XP-BL-SD-5600
Main features:
1. Improved specification produces balance level of torque & top speed so as to provide a more linear acceleration for the car.
2. High quality bearing to improve the smoothness.
SENSORED BRUSHLESS MOTOR 6800kv FOR X-POWER INDOOR TOURING CAR
Part Number XP-BL-SD-6800
Main features:
SENSORED BRUSHLESS MOTOR 7800kv FOR X-POWER INDOOR TOURING CAR
Part Number XP-BL-SD-7800
Main features:
Sensored Brushless Motor 5500kv for our IDT/IMT
Part Number XP-BL-SD-5500
The special features of this Black Edition motor are:
1. Believe to be the world smallest sensored brushless motor for RC products.
2. It's length is shorter than the existing one by 4mm.
3. It's weight is lighter than the existing one by 24%.
4. Shorter in length and lighter in weight of it help to improve the weight balance of the car.
5. 5500kv version provides a more low end torque. Suggest for racer who would look for more linear driving feel.
6. 6000kv version provides a more high end speed. Suggest for racer who would look for more punchy driving feel.
Sensored Brushless Motor 6000kv for our IDT/IMT
Part Number XP-BL-SD-6000
Sensored Brushless Motor 6000kv for MIT
Sensored Brushless Motor 6000KV
Old 2015.01.01, 11:25 AM   #6
GL Racing
GL Sensored brushless motor 3500KV
Part Number GMM-002-SD3500KV
GL Sensored brushless motor 5500KV
Part Number GMM-002-SD5500KV
GL Sensored brushless motor 6800KV
Part Number GMM-002-SD6800KV
GL HT Brushless Motor (2500KV)
Part Number GMM-001-2500
GL HT Brushless Motor (3500KV)
Part Number GMM-001-3500
Here's the in between 3500KV, as with previous motors in the GL range:
- linear power control.
- High efficiency of energy conversion.
- Better torque than Kyosho VE motor series.
- JAPAN high quality duel ball Bearing included.
- no power fade at higher temperatures.
- 15mm diameter.
GL HT Brushless Motor (6800KV)
Part Number GMM-001-6800
Here's the in between 6800KV, as with previous motors in the GL range:
- high efficiency
- 15mm diameter
New feature for this motor:
- End bell can be opened for cleaning and maintenance
GL HT Brushless Motor (8600KV)
Part Number GMM-001-8600
Motor developed with NiMH Mini-Zs as well as GLA in mind, very high power for expert users
More power - one of the most powerful motors out there, due to its High Torque, KV rating is not high, but more poweful than some higher KV motors on market
Easier to control - with a more linear power band making your car easier to control.
Longer run time - it also boast higher electrical efficiency than motors of the same class
Powerful til the end - Power level stays more consistent towards the end of each run, but this does mean that motor feels hotter at the end of run, because it stayed at high power levels until the very end.
Taller gear ratios - recommended GLA gear ratio from 8.2 to 9.5 depending on your driving style and track layout
TIP: Wiring is reverse to PN, so if you are swapping out a PN, swap any 2 of the 3 motor wires
GL HT Brushless Motor (5250KV)
Part NUmber GMM-001-5250
Motor developed with GLA in mind, enough power for experienced users
More power - a little more powerful than PN5500, but less than PN7500
Taller gear ratios - recommended GLA gear ratio from 5.4 to 6.1 depending on your driving style and track layout
Old 2015.01.01, 11:47 AM   #7
Reserved...
Old 2015.01.01, 11:50 AM   #8
manufacturer lists updated with most current information as of 12/1/2015.
Old 2016.10.14, 07:40 AM   #9
Updated Kyosho listings as of 10/14/2016.
Old 2017.02.27, 10:57 AM   #10
Traveler
of both Time and Space
Traveler's Avatar
There is a PN v2 3500kv (PNWC Stock) too!
Old 2017.02.27, 12:43 PM   #11
thanks updated the directory.
Old 2017.03.05, 02:48 PM   #12
updated with GL Racing options
Old 2019.09.06, 08:32 AM   #13
Looks like Kyosho has a new brushless motor closer to stock class rating of 4100kv and green coming!
https://rc.kyosho.com/ja/ths2019/?__...lniYOpFElya9mE
Old 2019.09.06, 02:27 PM   #14
mugler
mugler's Avatar
Pretty big news indeed and long overdue. Given the lowest FDR Kyosho stock gears offer is 4.889 the question becomes if the speeds will actually be close to any existing stock brushed or 3500 brushless motor or will it end up establishing it's own separate Kyosho only EVO stock class something in between existing stock and super stock speeds.
Old 2019.09.07, 12:28 AM   #15
I agree, track testing will need to be done to see where it stands in relation to the established class regulations. I do like the idea of 4000-4500kv motors though, I think it would be a great power level for racing on smaller HFAY style circuits where a 5500kv pwr is just a little more than needed.
"targetingxmod" Kyosho Mini Inferno brushless 4s targetingxmod Gallery 1 2013.05.05 05:26 PM
PN option parts for the new brushless Mini z??? DMALMAD PN Racing 9 2013.03.25 08:47 PM
Mini Inferno RTR/ARR Blowout & 40% all Mini Inferno Parts Mrs Mini-Z Promotions 0 2010.09.02 07:58 AM
shop.tinyrc.com: We're heating things up with a Mini Inferno Blowout and More! Mrs Mini-Z Newsletters 0 2010.09.01 03:51 PM
