Old 2003.03.19, 08:45 PM   #1
johnrtse
Happiness is 6x2 mosfets!
johnrtse's Avatar
Charging Soldered Battery Packs?
Can I use my Rayovac PS4 charger to charge soldered-together AAA 750 mAh NiMH battery packs, such as a 4-cell for the Pro-Z chassis or 6-cell for a Mini X?
Since I'll be using Deans plugs for my electrical connections, I was thinking of just making an adapter from a Radio Shack 9 Volt-style battery pigtail, and using the 9 Volt port on the PS4 for charging the battery pack(s).
I don't want to buy a new charger is I don't need to.
All thoughts and comments appreciated!
John
- Mad Max Interceptor: (clean version)
- Castrol NSX: (X speed motor, bearings, a bunch of alloy stuff, etc...)
- Lancia Stratos: (bone stock)
johnrtse is offline   Reply With Quote
Old 2003.03.19, 08:54 PM   #2
BigVxxx
Mini-Z pro
BigVxxx's Avatar
Re: Charging Soldered Battery Packs?
I'm not famillar with the ps4 but recomend buying a better charger. You can get a realitivley cheap NiMH charger these days . I use my 1/10 scale charger for my miniz. I peak charge 4 750's at around 1.5 amps. Check out the Piranaha.
BigVxxx is offline   Reply With Quote
Old 2003.03.20, 12:57 AM   #3
ShauLinMonk
Mini-Z Novice
ShauLinMonk's Avatar
Send a message via ICQ to ShauLinMonk Send a message via Yahoo to ShauLinMonk
BigVxxx... there's nothing really wrong with his charger... he's asking if SOLDERED together batteries would work on his PS4 (which I have as well, although the batteries can get hot sometimes).... unfortunately johnrtse, I do not know if/how you could do it.... sorry dude!
RiDe or Die....
ShauLinMonk is offline   Reply With Quote
Old 2003.03.20, 02:09 PM   #4
Digisane
Mini-z Crash Test Dummy
Digisane's Avatar
I think. On the pro-z site Scott would have a section on it up.. it is still not linked up yet but i've been folowing his site, the sites are constantly updated so im sure he'll have a section on it.
Digisane's NSX - |
Blue Pro-Z Chassis - hard Diamond plate - 3º Castor - 1.5º Toe-in tie rods - alloy rims - bearing motor - Silver 2001 NSX body
Digisane is offline   Reply With Quote
Old 2003.03.20, 02:33 PM   #5
BigVxxx
Mini-Z pro
BigVxxx's Avatar
All thoughts and comments appreciated! [/B]
Hey, ShMonk informed me I miss understood your question. Sorry. I don't know why you want to make 4cell packs for miniz's(saddle packs/2 aside?). Sound like some serious s**t.
Let me know if it works out for you!!!!!
Get word to WestF1 of your idea.....he use to use rayovac's charger. There's a few racers at our club who might know......check out ThomThumb in regional clubs at this site.
Friendly Reminder: NiMH batteries are considered high maintenance batteries like NiCad which require regular discharging cycles to prevent voltage depression. "Crystaline Formation" occurs in these batteries resulting in capacity loss due to there nickel plating. Miniz batteries are inexpesive, but if your going to make packs you may want to think of a new charger in the future Good Luck and Good Racing!!!!!!!!!11
Lacrosse BC-900 Alpha Power Battery Charger arch2b Batteries, Chargers and Dischargers 41 2007.10.24 07:25 PM
Battery Charging Blacker24 Batteries, Chargers and Dischargers 5 2006.10.27 03:55 PM
NiMH Battery Info G-Class Parts and Hop-ups 5 2004.09.09 11:29 AM
Battery Charging part4a Off-Topic 6 2002.09.10 09:26 PM
charging battery fuse01 Beginner Questions 0 2002.02.04 03:47 AM
