Old 2007.12.05, 12:08 AM   #1
archenok
No reverse and steering problem off new RTR
Hi all,
I recently got a new RTR MR-015RM
When I turn it on, the wheels refuse to straighten out on me, and also I have no reverse. I've tried all the trim dials as well as the trigger position dials. My hunch is that the radio is faulty... i certainly hope not
Is there anyone who's encountered and fixed the problem?
archenok is offline   Reply With Quote
Old 2007.12.05, 07:30 AM   #2
hrdrvr
hrdrvr's Avatar
If its a recent purchase give K america a call. They should swap/fix it for you free of charge. If you know some one with a Tx you could try that first to isolate the problem, but Id send the whole thing back for a replacement.
BTW, if you have a different crystal set, you could try that as well.
Landon
LET's Go Racing!
Old 2007.12.05, 06:12 PM   #3
archenok
well i found reverse - it's just quite moody and doens't always work i.e. if i squeeze it in reverse gently the car sits, but if it flick it into reverse it will work
i can live with that - now i just have to figure out how to centre the steering mechanically, if possible - the car survived my first pulling apart of it, so that's good. Tried fiddling around w/ the steering gears a bit, but it made no difference. I'd be happy if i could even pull apart the Tx and see if i can do something to centre the steering, but i don't know how to get around the on/off switch.
and in terms of exchanging - i bought this off ebay, and some how from playin with it, i've already broke a mirror (i have no idea how... it's a 935... the mirror is TINY)
otherwise right now i just turn the trim and steering sensitivity to max and try not to be too butterfingered when playing
n/m - using that LH KT5 tutorial I managed to take the Tx apart - there was a little knob beside the sensitivity dial - fiddlign around w/ that solved the problem (there'll be more mirrors flying off now)
Old 2007.12.05, 10:00 PM   #4
flicking trigger forward once will activate the brakes.... flicking it forward twice will activate the reverse function... welcome to the forums....
as for centering... try the search function and type in "how to center steering"
Old 2007.12.06, 05:39 AM   #5
byebye
byebye's Avatar
Did you read the manual front to back?
Kris
Old 2007.12.06, 09:15 AM   #6
imxlr8ed
imxlr8ed's Avatar
Make sure your throttle trim is set as far in the forward direction as possible without moving the wheels. You'll hear the fets start to sing a little (a soft & quiet little beep beeep... beep beeeeep beep... beeeeping noise ), get it to the point they make sound, then back the trim off the opposite way just a hair from that point. (until the noise stops)
Each car has a different throttle trim point which is true center, if the throttle trim is off more towards the reverse direction, it may be near impossible to get the car to back up quickly.
Some drivers actually run their cars with a constantly pinging forward throttle to reduce drag braking into corners, not enough to push the car from a stop on it's own, but enough to help carry some speed into the corners. (I used to do this with my Neo-mag equipped cars once in a while)
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
iWaver02 steering twitch / steering steps FIX!!! trueno92 iWaver 0 2005.04.23 12:09 AM
Strange Overland problems... Like nothing I've seen before Ryan Gardner Mini-Z Overland MV-01 6 2005.01.10 10:44 PM
Problem going into reverse? TeaQue Mini-Z Monster MM-01 10 2004.08.03 09:15 PM
Problem with glitching, reverse. davkin Mini-Z Science 3 2004.02.22 02:33 PM
Micro RS4 RTR Review pkh Mini RC 7 2002.10.11 09:34 PM
