Old 2009.10.30, 02:07 AM   #1
PridgeoK
PridgeoK's Avatar
FS: AM Formula 1 - minus radio
* * * * * * * SOLD * * * * * * * * * *
Contact:.......PM
Description:..Formula 1 - AM model - no radio
Here's one of my F1's that I've had great fun with. I'm moving to a 2.4 version though, so it's hopefully going to someone who will enjoy it as much as I did.
This car does have some minor steering twitch, so a POT replacement is probably in order, but otherwise it works as expected. Here's what I can tell you about it:
- single stack of 4562's
- tie-rod clips are gone, so included is the ATM alloy tie-rod holder - like new condition
- 1 degree ATM tie rod - you'll want to replace this...
- 0 degree titanium ATM knuckles - good condition
- sheilded bearings (only 6 of them though - 2 in the rear instead of 3)
- not too sure what the tires are, but they are probably some soft PNs... lots of tread left, as they are lightly used
- original Potenza hard-ass tires and wheels will be included
- original plastic knuckles will be included
- will come with the original x-speed motor - works well
- will come with a full set of the small-plastic-parts package (unopened, just the label taken off to fit in with my gear)
- all screws, c-clips, and the full set of pinions and motor guides will be included
- I'll throw in the new-in-package rear wing
- front wing has been glued and is in fair condition
- front bumper has been run but is in ok condition
- body has been slightly modified to fit the I-Lap transponder, so the bump over the servo-gears has been ground down, the underside of the driver as well, and a piece of exposed 35mm film has been put under the driver so the transponder can see the sky without looking like a gaping hole. Looks good and works great! Other than that, the main body is in pretty good condition, having been replaced not that long ago.
- the transponder connector for the giro-z is installed - it's the same connector I use for the I-Lap transponder... If you don't want it, I'll remove it before shipping.
- won't come with a radio or crystals unless you really need them - let me know and we can negotiate on those if you do. I want to keep one of the KT5's I have to mod it into a lefty, since we have a few people who are in need.
- forgot to add: silver lock nuts as well, and...
- those are the kyosho stainless king-pins. I can throw in the originals as well if you want.
Please use PM's - replies in the marketplace are now seller-only.
Thanks,
Kevin.
PridgeoK is offline   Reply With Quote
Old 2009.10.30, 07:14 PM   #2
PridgeoK
PridgeoK's Avatar
SOLD.........
Kev.
Old 2009.11.02, 11:27 PM   #3
PridgeoK
PridgeoK's Avatar
Bump! Time to drop the price.
Old 2009.11.10, 06:08 PM   #4
PridgeoK
PridgeoK's Avatar
...the price drops again.
Old 2009.12.16, 02:12 AM   #5
PridgeoK
PridgeoK's Avatar
This car is now sold.
Tags
formula one, mini-z
Formula 1 color01 Mini-Z F1 MF-010, MF-015 0 2009.07.12 02:18 AM
FS: Highly modified KT-18 radio color01 Mini-Z Marketplace 0 2008.09.11 01:45 PM
About the iWaver Radio ... 1ofdfew323 iWaver 15 2006.07.09 06:34 PM
Questions for Airtronics Radio Owners Spoon Miscellaneous Discussion 6 2006.06.05 11:22 AM
FS: Ko Propo Mars R radio for Mini-Z - $150 pchan0 Miscellaneous Discussion 0 2003.08.25 04:52 PM
