Old 2007.03.07, 03:45 AM   #1
Programmers
iTomCash
X-Mod: 1967 Chevrolet Camaro
Drive
RWD
0 degree Steering
Hard Suspension
Locked Differential
10 Tooth Gearing
Bearing Upgrade
Carbon Fibre Drive Shaft
Full GPM
Thick Tread Tyres
Power
Plasmatonic Motor with Capacitor
Stacked FETs (2x2)
2x 3.7V Lithium Ion
Top Speed
74 KPH (46 MPH) on 10 Tooth gearing and slip diff (Scroll down for picture)
Old 2007.03.08, 06:09 AM   #2
Flat 4 Racing
Very cool Camaro! What are you using for track?
-Dan
Real Cars
1994 Chevrolet B4C Camaro
2004 Subaru Impreza WRX STi
XMods
Flat 4 Racing is offline   Reply With Quote
Old 2007.03.08, 02:48 PM   #3
Programmers
iTomCash
Thank you.
I am using gym foam flooring,
Old 2007.03.08, 03:30 PM   #4
Flat 4 Racing
Originally Posted by Programmers
Thank you.
I have some of that stuff also, but it's in much smaller panels; probably like the size of magazines, or 1ft X 1ft pieces. They sort of suck because of all the "seams."
-Dan
Real Cars
XMods
Old 2007.03.21, 04:54 AM   #5
Programmers
iTomCash
Mask the joints if it's a problem. That'll work fine. Also, on ebay, you can pick up 2ftx2ft packs of 4 for 8 posted, then another 2 for the next pack.
Old 2007.03.21, 09:28 AM   #6
ChattavegasSE
Zoom Zoom!
Send a message via AIM to ChattavegasSE
It needs more tire contact! Try doing doughnuts on sandpaper; that'll smooth those tires down so you can get better traction.
I got nothing.
ChattavegasSE is offline   Reply With Quote
Old 2007.04.15, 06:20 PM   #7
Programmers
iTomCash
Now it's up and running again I put it on a Dyno. Here's the top speed. It did hit 74kph but I'm not sure if it was photographed.
This works out at 45.98 MPH.
It should run quicker next time around 'cause I'll secure the tyres on better and use some com drops and motor bearing grease.
Transposed brush mod for the ATOMIC bb can.... ph2t Motor Tech 3 2007.01.07 09:01 PM
LiIon mod ! What motor ? Vadda Mini-Z Monster MM-01 13 2005.03.06 07:07 PM
Plug in FET Mod msyko Mini-Z Science 24 2003.04.25 02:38 AM
RMYC's Antenna Light Mod rmyc Mini-Z Science 6 2003.03.19 06:18 PM
