Old 2006.08.07, 03:41 PM   #1
pchan0
Team ShoBoi
pchan0's Avatar
Send a message via ICQ to pchan0 Send a message via MSN to pchan0
Kyosho MA-01 Set Up Thread
How about this guys? To the guys that race the MA-01 competitively at your local RCP track post your set ups here for others to try, I know there is alot of different factor that the set up you posted here might not work on others track but you can just get an general idea of what people are running. I'm not sure if there is a MA-01 set up sheet existed so how about we do something like this? Please post if there is a set up sheet for the MA-01.
RCP Track traction - low, med, high
Layout - fast, technical
Gearing - ...
Body - ...
Wheelbase - ...
Motor - ...
Front:
Toe - ...
Camber - ...
Spring - ...
Lowering spacer - ...
Spring spacer - ...
Drive - diff, oneway, spool
Wheel offset - ...
Tire - ...
Special notes - ...
Rear:
Toe - ...
Camber - ...
Spring - ...
Spring spacer - ...
Drive - gear/ball diff
Wheel offset - ...
Tire - ...
Special notes - ...
pchan0 is offline   Reply With Quote
Old 2006.08.07, 04:21 PM   #2
Limeaway
MA-010 Owner
Limeaway's Avatar
Send a message via AIM to Limeaway
http://www.kyosho.co.jp/web/download/setting/index-e.html
MA-010 Set Up sheets
Target Foam Mats
Layout - Small and Fast
Gearing - 15pinion/31spur
Body - Skyline GTR Nur V-SpecII
Wheelbase - 94mm
Motor - Stock
Bearings - Kyosho
Front:
Toe - 0
Camber - 0 Alloy 3Racing
Spring - Hard (gold) 3Racing
Lowering spacer - 1mm left and right
Spring spacer - None
Drive - ATM Ball Diff Loose
Wheel offset - 0
Tire - Stock AWD Tires
Special notes - Both front wheels are double Shimmed, 3Racing Alum. CVDs
Rear:
Toe - 0.5
Spring - Soft (Black) 3Racing
Lowering spacer - None
Drive - Ball Diff a bit tighter than factory settings
Wheel offset - 0
Special notes - Both Wheels Double Shimmed, 3Racing Alum. CVDs
Limeaway is offline   Reply With Quote
Old 2006.08.07, 04:44 PM   #3
pchan0
Team ShoBoi
pchan0's Avatar
Wow, Kyosho Japan has a general set up for us F430 user? Sweet!
Thanks for your set up too. I'm running on those grey foam mats too...
Old 2006.08.07, 08:05 PM   #4
hobbycar
hobbycar's Avatar
RCP Track traction - med
Layout - 60% fast 30% technical
Gearing - 17/31
Body - Ferrari 360 GTC
Wheelbase - 94mm
Motor - stock
Bearings - yes
Front:
Toe - stock
Camber - 1* (Kyosho plastic)
Spring - stock
Lowering spacer - 1 lowering spacer on bottom
Spring spacer - none
Drive - stock diff w/ 50,000 wt diff grease
Wheel offset - 2.5mm (Narrow) (less than suggested 3.5 for 360GTC)
Tire - Kyosho 20 slicks (semi-wide)
Special notes - 3Racing CVDs/Swing-Shafts (only because my stock one broke)
Rear:
Toe - stock
Camber - 0* (plastic stock)
Spring - stock
Wheel offset - 1mm (Wide)
Tire - Kyosho 20 Radial
Special notes - stock plastic CVDs/Swing-Shafts
HFAY OLPS Season1 Race 12 2nd place overall with 90 laps - 08:03.49
Video (my car is the white Ferrari 360GTC) (it took me a couple laps to settle into a groove )
-hobbycar
I'm going to try the Kyosho 20 Radials in front and maybe lower the front just a little bit more for the next race.
hobbycar is offline   Reply With Quote
Old 2006.08.09, 02:49 AM   #5
jaeneke
miniZ teletubbie
RCP Track traction - high
Layout - technical (2 mini96 rcp's + 2 extension packs put together)
Gearing - doesn't really mather but not highest gearing
Body - murcielago
Wheelbase - 98(extension kit)
Motor - pn speedy 05 BB(from mr02)
Front:
Toe - 0
Camber - 1
Spring - atomic red(soft)
Spring spacer - ...
Drive - ball diff atomic
Wheel offset - +1.5 narrow(should be 2.5 wrong wheels)
Tire - 30 atomic competition
Special notes - pn upper deck + camber knuckles for minimum friction
Rear:
Toe - 1
Camber - 1
Lowering spacer -
Spring spacer -
Wheel offset - +0.5 wide(wrong wheels, should be +3.5 or 4)
Tire - 20 atomic competition
Special notes - pn upper deck and camber knuckles for minimum friction, bleu/gray chassis, fet upgrade, motor heat sink, 3racing alloy swing shafts, titanium kyosho center shaft, ball bearings.
garage :
kyosho miniZ MR02 2.4Ghz
kyosho mini inferno : atomic tuned + brushless + 11.1V 3C lipo
HPI savage : 35 full fastlane alloy 4.6BB
hormann HT2 bigscale 26cc
team losi miniT PRO
team losi microT lipo
jaeneke is offline   Reply With Quote
Old 2006.08.09, 03:27 PM   #6
pomme de terre
pomme de terre's Avatar
jaeneke, how tight do you run your diffs?
pomme de terre is offline   Reply With Quote
Old 2006.08.09, 03:47 PM   #7
jaeneke
miniZ teletubbie
mmm... hard to say but fairly loose on the front and the rear in that way if you block the rear wheels that the diff slips when you give 'full' throttle.
i think about 50% in the front and about 75% in the back, if you tighten the front diff harder then you get more oversteer and vice versa !
garage :
team losi miniT PRO
Sas Pro Set Up. Cherub1m Mini-Z AWD MA-010, MA-015 310 2011.05.24 10:08 PM
Kyosho AWD Aluminum Wheel Set question.. doongas Mini-Z AWD MA-010, MA-015 2 2006.08.11 04:56 PM
Anybody interested in a AD band car set up? pchan0 Miscellaneous Discussion 8 2005.12.29 10:57 PM
Kyosho Shock Set.......grrrrrrrr Sky Parts and Hop-ups 6 2003.04.25 06:19 PM
FOR SALE Kyosho Oil Damper springs set sc0627 Miscellaneous Discussion 0 2003.03.03 03:15 PM
