Old 2014.03.23, 09:19 PM   #1
byebye
byebye's Avatar
Byebye's Porsche 906 86mm class build thread
Well I received this body from Mr. Arch2b this past race weekend as we are switching to 86mm class in a few months. Everyone knows how high this body sits on the chassis and me being me I really dislike it...Anyway I chopped it up and made some chassis changes and this is what I came up with. Enjoy!
To make this work-
  • Grind the inside of the front of the body
  • Remove and modify the side mount area so that you can get it seated as high up in the body as possible
  • Reverse the king pins
  • PN Racing RM motor mount
  • 17mm round motor by Atomic
  • Use the F40 carbon front body mount with the PN adapter and flip the adapter
  • I used the stock wheels and tires. The rears are from the asc. The fronts are Kyosho 40
I am also running the PN 90RM mount and multi-length disk damper. I used the stock kyosho plastic rear shock post mounted to the motor mount without the aluminum stand-offs. I just ran a machine screw through the top down into the motor mount.
I ran a few laps and no issues!. I really thought the rear would rub but it doesn't. It could use a wing and the tires will need to be taped or glued.
Old 2014.03.23, 10:01 PM   #2
lfisminiz
lfisminiz's Avatar
Sweet looking!
Old 2014.03.23, 10:19 PM   #3
byebye
byebye's Avatar
Originally Posted by lfisminiz View Post
Sweet looking!
Thank you.
I had to nip the kingpins and that made a huge difference in the handling. I guess it was dragging.
I did use some 30 fronts and those are the right tires for race day. The 40's give you that slight bit of understeer needed for those stock asc radial tires.
The grip at our track is pretty consistent so I imagine the 40's will work. I haven't searched yet if they make a high grip radial for the 906.
Old 2014.03.24, 08:34 AM   #4
Traveler
of both Time and Space
Traveler's Avatar
Nice! What are your thoughts on the 35T Plus?
Old 2014.03.24, 04:22 PM   #5
byebye
byebye's Avatar
It's smooth and not a torque monster like the regular T2. It's way too much motor for this setup. Could be better with a 70t but I haven't tried that yet.
Added some chassis and transponder pic.
Old 2014.03.24, 07:29 PM   #6
Cool
What rear damper is that? I have the Kyosho oil shock on mine and that eats up space I could use for the transponder
Old 2014.03.24, 08:15 PM   #7
byebye
byebye's Avatar
It's the PN damper.
Old 2014.03.24, 10:32 PM   #8
what other options are available for the nose clip? that seems to be the biggest stumbling block as i only use the stock plastic nose clips. i'd like to get mine down at least half as low.
what did you use to get he body clips out? mine are in there night and tight.
Old 2014.03.25, 06:40 AM   #9
byebye
byebye's Avatar
Other options are styrene only. Styrene with the PN adapter or matching a mount dimensionally from another body and modify it.
I think you should get the adapter and a sheet of styrene and go at it
To get the body clips out I used a small flat tip and pried them gently. You will need to trim the mounts inside the body and don't forget to shave a little off the top of the clip(45deg cut). The body is very curved there and the clip will not seat fully if you don't trim. Just remember to dry fit everything before you glue.
Old 2014.03.25, 07:45 PM   #10
well, tried to pop the mounts off very carefully and they took 90% of the fins with them so looks like that is a bust for me lets hope goop can hold them in. i set them 2mm down from bottom out on the body so it's at least a 2mm drop. i poured goop in the front end to make sure the buckets don't break out as well.
Old 2014.03.25, 09:56 PM   #11
byebye
byebye's Avatar
Darn...I've contemplated getting the white body and doing it right instead of trial and error. 2mm is more than before and still a significant drop.
Old 2014.03.25, 10:09 PM   #12
lfisminiz
lfisminiz's Avatar
Ray, had that happen to me already. I gooped hot glue on clip area. Worked great.
Old 2014.03.27, 08:55 PM   #13
filled with goop, then a layer of shoe goo to top that off.
now a bigger problem... the body is 2-3 mm lower and the stock RM pod is hitting the read deck lid. looks like i need to go back to stock, don't really want to buy another brushless motor.
Old 2014.03.28, 05:39 AM   #14
byebye
byebye's Avatar
Really? I'm running the PN rm pod and a 17mm motor. Interesting. I would not have thought it would hit. Got pics?
Old 2014.03.28, 07:32 PM   #15
see the attached. zero movement between the body and body.
Byebye's F40 90mm class build byebye Autoscales, Bodies, Cars and Drivers 16 2014.03.05 08:18 PM
Carolina Cup Challenge - 2011 hrdrvr Carolina Cup 120 2011.03.10 05:25 PM
MHS 2012 PN Regional!! ruf993 Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 58 2010.10.29 11:17 PM
My Suggestion for Next Years Racing Format JuniorWKR PN Racing World Cup 43 2009.11.04 11:05 PM
MHS is Hosting a PN Racing Mini-Z World Cup 2009 ruf993 Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 133 2009.07.27 10:38 PM
