Old 2012.11.06, 06:11 AM   #16
NoBrainer
NoBrainer's Avatar
I'm using "Talk" and set it to english language and "normal" speed.
Tested it with it's build in text.
So then I got speech.
Installed ZRound and configured it with, ip, port and transpondernumber.
Then I checked everything but the "best lap today reading".
It all worked right out of the box for me.
Only thing is that I would love it to check the computer for best lap and not just use best lap since the ZRound App started. Since I started testing ZRound App after 600 laps....
Old 2012.11.19, 04:00 AM   #17
NoBrainer
NoBrainer's Avatar
One other thing is that it just reads 6.05 and not 6.053.
Can't change this in the App, might there be a setting in Android for language or something??
Old 2013.01.11, 06:30 AM   #18
dvo
dvo's Avatar
Originally Posted by NoBrainer View Post
had to install a new browser to get it to work.
it would be great if you could see the settings when you choose settings.
I have the same problem, with browser did you used ?
RC racing isn’t a crime, loosing is, I'm a criminal.
dvo is offline   Reply With Quote
Old 2013.01.11, 06:32 AM   #19
NoBrainer
NoBrainer's Avatar
It did not work with the browser that came with Samsung Galaxy S3 and Android 4.1.1.
I use Opera now and it workes better.
Old 2013.01.11, 08:48 PM   #20
I dont know s*&% about android devices but typing this on my wifes galaxy tab2. How on earth do i install this?
Old 2013.01.12, 12:06 PM   #21
zround
You must first to change the phone security settings in order to accept app from unknown sources (as it isn't available from the playstore yet).
When you download the installer the browser warn you there is not an application defined to open the file and you will be asked for downloading, then you should be able to install it when click on the downloaded file.
If you still can't open the file, you could try another browser or a file manager like "Astro" (I've just used it on my wife's HTC One).
Regards,
Jesus.
Old 2014.03.29, 11:18 AM   #22
i finally got an andriod device. my wife upgraded to the galaxy tab pro and gave me her tab 3. changed settings, downloaded and installed without to much fiddling around.
how does this connect, wifi, bluetooth?
Old 2014.03.29, 12:10 PM   #23
zround
It's wifi. You must define the transponder number or the racer's name in the settings.
Check the "Remote" configuration page in ZRound. It must be enabled too.
Old 2018.04.30, 01:08 AM   #24
benwih
Do I have to manualy enter the transponder number every time I use zround for android? I wish there is an option so that we can simply click on the registered transponder. it will make it easier if we have multiple transponders
benwih is offline   Reply With Quote
ZRound Companion application for the BlackBerry PlayBook Sinister_Y ZRound 12 2012.11.14 10:17 AM
ZRound Suite update 1.10.10 zround ZRound 1 2011.09.14 02:06 AM
ZRound Suite update 1.10.4 zround ZRound 4 2011.02.06 04:36 AM
ZRound Suite update 1.9.8 zround ZRound 0 2010.05.08 02:15 AM
ZRound Suite 1.9 zround ZRound 10 2010.02.19 12:25 PM
