Old 2005.01.16, 07:47 AM   #1
Bandie
F1 Racer
Bandie's Avatar
Send a message via ICQ to Bandie Send a message via AIM to Bandie
How to change the play between Spur gear and pinion gear on F1 ?
Hi F1-Racers,
to get the optimal gap/play between the Spur Gear and the pinion Gear normally in RC-Cars the best way is to use two screws to adjust it exactly.
As all knows the F1 has just 2 black plastic pieces that can be installed in 3 different ways to use pinions between 6-9.
Question:
Does someone did manage to adjust this or has an idea how this can be done?
I guess a change of just 0,2mm .. 0,6mm is enough!
Play is a little too much on my F1!
High noice and performance loss is the result.
regards, BANDIE
Bandie's Racing Board!
Bandie is offline   Reply With Quote
I broke my Pinion gear :( philophob Beginner Questions 5 2008.03.12 08:58 PM
Spur gear skiping Atomic diff in SAS WeBoC Mini-Z AWD MA-010, MA-015 13 2007.03.06 02:21 PM
Whats the Pinion Gear, Spur Gear relation? G'ZOX Setups 5 2004.02.16 01:19 AM
pinion and spur gear questions racerdx6 Parts and Hop-ups 4 2003.07.05 09:18 PM
differential and pinion gear upgrades RCPMini-z Beginner Questions 3 2003.06.02 01:55 AM
