Old 2013.05.11, 11:01 PM   #16
I googled the image...Red sentra looking car with a white or grey top? That should be easy enough for you to do.
Are you planning number plates and company livery?
Old 2013.05.12, 12:22 AM   #17
gctkaz
Toyota Crown, I believe...
Yea, the overall colour scheme is easy and I can probably handle it, it's just the decals and stuff that I've not any experience with, and I don't even know if it's a popular enough set to have any production at all. Anyway, that probably won't happen for a while. Depends how spendy I feel since I'm pretty happy with the bodies I have at the moment. It would just be for poops and giggles to drive a taxi on the track. It's a pity the two Chevy Caprice ASCs are out of production, that would save me all the trouble.
gctkaz is offline   Reply With Quote
Old 2013.06.19, 09:07 PM   #18
I just made a pretty fantastic discovery:
If you use water based acrylic paints (like the Tamiya paints pots I use) and you want to start again fresh you can use OxyClean as a paint stripper! I was attempting to soften some decals on a body for removal and it softened them and stripped all the paint of a body I had planned a redo on anyways....
i used this other body below as a test mule (since i'm redoing this one as well)
before:
after being immersed in hot water and one scoop of OxyClean for 10 minutes tops:
2 things:
1.It doesnt strip decals...I had to scrape the decals away and then re-soak a bit to remove the paint underneath
2. It doesnt appear to have the same effect on laquer based paints. I tested my paint tester body (which has a variety of rattle can and water based acyrlics on it) and the rattle can laquer based paint did not come off with the same gusto. I may super soak it to test some more
Looks like I won't be buying large bottles of simplegreen any more.
Old 2013.06.20, 12:30 AM   #19
DaveW
That looks like it cleaned off the old finish REALLY good!
That's impressive.
DaveW is offline   Reply With Quote
shop.tinyrc.com: We're heating things up with a Mini Inferno Blowout and More! Mrs Mini-Z Newsletters 0 2010.09.01 03:51 PM
Tips and Tricks to Building an Ma-010 ScoobyPete Mini-Z AWD MA-010, MA-015 5 2010.03.22 05:47 AM
Tips and Tricks on the NML SSV.3 NOMOTORLIMIT Motor Tech 1 2005.02.20 04:49 PM
Overland Tips and Tricks DAMZer Mini-Z Overland MV-01 19 2003.06.21 05:13 PM
Mini Z vs Colt Mini Justin Miscellaneous Discussion 71 2002.01.18 08:31 AM
