Old 2002.08.31, 06:33 PM   #1
ScottMcLeod
Send a message via ICQ to ScottMcLeod Send a message via AIM to ScottMcLeod Send a message via Yahoo to ScottMcLeod
Weight... I need help packin on the pounds...
I need help deciding where, and how much weight to add to the car to make it handle more realistically.
Most cars in real life wouldn't start doing donuts if you accelerated too fast... they'd just burn out and squeel the tires.
I'm having trouble getting my Z to grip with the fronts. Weight seems like a fair solution, because if you take the scale weight as well as size of a mini-z... it should be like 100 pounds.. but it's only in the 100-150 range.
-Scott
ScottMcLeod is offline   Reply With Quote
Old 2002.08.31, 07:49 PM   #2
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Weight a minute... that's been discussed before
Scott,
Read this:
http://mini-zracer.com/forums/showth...&threadid=1136
Mondo
__________
Old 2002.08.31, 08:31 PM   #3
ScottMcLeod
Thanks mondo.
I've decided to start adding weight to my Z to help it perform.
I find the power to be overly sufficient with NiMH'es and a 9t pinion, and I can still easily spin out the wheels, and have massive understeer...
-Scott
Old 2002.08.31, 09:22 PM   #4
The Thunderer
The Thunderer's Avatar
Originally posted by ScottMcLeod
Thanks mondo.
Just remember that if you do add weight, that adds to the car in everything... including crashes!!! So, a car's crash will be much worse with more weight on the car.
"Its the least I can do for the Captain of the Enterprise."
"Where there is lightning, there is The Thunderer."
The Thunderer is offline   Reply With Quote
Old 2002.08.31, 09:46 PM   #5
ScottMcLeod
Crashes? What are those? Doesn't sound like anything i've done before...
Yes, I know, but the un-realism of the massive acceleration donuts and loss of control into donuts, and everything into donuts is really getting on my nerves ;-)
-Scott
Old 2002.08.31, 09:47 PM   #6
Wedginator
The Thunderer,
You got that rite. I taped a couple coins inside my car and the crashes were louder than b4....
Old 2002.09.02, 11:24 AM   #7
scottmcleod...
hi... check this thread out... it's kinda long... i put tamiya 4wd weights on my vitz... on the front bulkhead (4grams), and under the motor mount (4 grams) ...
http://mini-zracer.com/forums/showth...t=lead+weights
Old 2002.09.02, 11:32 AM   #8
just wondering... anybody else still keep weights on their cars???
Old 2002.09.02, 11:51 AM   #9
Russ
Super Moderator
Russ's Avatar
Re: Weight... I need help packin on the pounds...
[B]Most cars in real life wouldn't start doing donuts if you accelerated too fast... they'd just burn out and squeel the tires./B]
Most cars in real life won't go over 500 scale miles per hour and have, who knows, like 5000 scale horsepower!!!
LOL Anyway, I get what you're saying I always say this but I'm not going to explain it again because noone seems to like my "tweak idea", but if your car starts doing donuts off the line when you gun it, you need to check your H plate tweak.
Russ
Old 2002.09.02, 12:15 PM   #10
Kid_CojoneZ
Guest
Posts: n/a
I've heard of adjusting tweak (tweaking , I guess) on bigger scale cars, but your the first to mention it in relation to a Mini-Z!
It makes sense, I guess, but difficult to achieve. Not so much for the H-plate tweak, but trimming the front coils would be a pain in the a$$...
Old 2002.09.02, 12:16 PM   #11
Russ
Super Moderator
Russ's Avatar
I've explained this maybe 10 times or more on the forums, lemme see if I can find one of them
Russ
Old 2002.09.02, 12:17 PM   #12
Russ
Super Moderator
Russ's Avatar
Here's one:
http://mini-zracer.com/forums/showth...&threadid=3307
and here is the latest one:
http://mini-zracer.com/forums/showth...&threadid=4182
Russ
Old 2002.09.02, 03:05 PM   #13
ScottMcLeod
Hrm... All very good information, thank you!
I'm thinking about the whole roll-shock setup. I like that very much, and it seems much more realistic than the dinky H-plate.
I'm going to add some weight in the front between the wheels, and in the back below the motor mount.
-Scott
saving weight on the stock chassis reggiethedorf Mini-Z Racer MR-02 9 2005.12.07 01:17 AM
Adding Weight to Stabilize Shaun Mini-Z Science 6 2002.06.04 03:03 PM
The Science of weight Mondo Mini-Z Science 30 2002.02.17 04:25 PM
Weight VS Performance hoi Setups 36 2002.01.20 11:47 PM
