2013.02.09, 02:58 PM
pyschopath racing
Carolina Cup rules (please no discussion here)
RACING CLASSES
GT1, GT2 - LMP1,LMP2 - CanAm1,CanAm2 - Sportsman GT/LM -F1,F2
SEE RULES BELOW:
Grand Touring Classes
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Electronics: Unlimited.
Batteries: 4 x AAA NiCad, NiMh or Alkaline (Lithium based batteries NOT allowed)
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
GT1
Min Weight: None.
Motor: Any 130 size brushed motor. Brushless not allowed.
GT2
Min Weight: 175g with transponder.
Motor: Spec motor designated by the Event.
Le Mans Prototype Classes
Wheel Base: 102mm only
Body: Kyosho LM-LeMans Prototype ASC or White Body only:
Porsche 962, any version.
Mazda 787, any version.
Sauber C9, any version.
Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. A maximum wheel opening of 32mm measured horizontally must be maintained. Cabin windows must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 60mm max
Wing: All wings original to the body are legal. Aftermarket or non-original wings must fit within confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Batteries: 4 x AAA NiMh or Alkaline (Lithium based batteries NOT allowed).
LMP1
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber tires (no foam).
Min Weight: None.
LMP2
Front: 9 x 18.5mm max
Rear: 11 x 20mm max
Tires: Kyosho LM specific tires only.
Can Am Classes
Track Width: 85mm max
Wheel Base: 90-106mm
Body: Atomic VDS (any version), PN Pan Car (any type), Le Mans Prototype or Can-Am style polycarbonate (Lexan) body (open or closed ****pit), Kyosho Le Mans ASC, White Body or similar.
Width: 85mm max.
Length: 200mm max
Height: 60mm max
Wing: No limitation other than must fall within Body Width-Length-Height envelope.
CanAm1
Min Weight: None.
Front: 11 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber or foam tires.
Batteries: 7.4V max. (Lithium based allowed).
Motor: Any 130 size motor. Brushless allowed.
CanAm2
Min Weight: 170g with transponder.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Sportsman GT/LM
Chassis: Any 1/28th scale or similar 2WD or 4WD chassis.
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, including LM-LeMans Prototype bodies
Motor: Stock Kyosho or Stock PN 70T.
F1
Chassis: Kyosho Mini-Z F1 chassis only!
Wheel Base: 130mm only
Body: Kyosho Mini-Z body (ASC or prepared white body) only!
Width: 85mm max.
Length: 210mm max
Height: 50mm max
Wing: No wider than 58mm. Mounted no higher than 45mm.
Min Weight: None.
Wheels: Any Mini-Z Formula 1 type wheels, plastic or aluminum.
Tires: Any Mini-Z Formula 1 rubber or tires.
Batteries: 4aaa NiMh only.
F2:
Chassis: Kyosho MiniZ F1, (200g pre race weight with Giro Z transponder)
Body: Kyosho F1 ONLY
Wheels: Any plastic or aluminum Mini-Z F1 wheels
Tires: F1 rubber tires, no foams, no traction compound
Electronics: No limitations
Motor: 70t Cup motor, which will be issued at sign in, and returned at the end of the event
Batteries: 4xAAA batteries, no lithium
