kyosho tube grease are yellow so they're the 15,000.
Too thick for gear diff, I tried 1000 & 5000 with really good results. I think 5000 was more in the sweet spot. use only a dab though, enough to cover satellite gears with a thick coating.
Thanks for the response! I have the 5,000 and will give it a try. But the grease in the tube didn't feel nearly as heavy or tacky as the 15,000 gear diff grease.
Thanks for the response! I have the 5,000 and will give it a try. But the grease in the tube didn't feel nearly as heavy to tacky as the 15,000 gear diff grease.
I noticed the same thing when squeezing out only a little out of the tube. At some point I was going to empty out an entire tube and give it a good mix to see if it will get close to heaviness of 15,000 out of the regular container but never got it.
