everybody knows how the merc clk looks like, so here is my car without the body. Hop-ups used:
Kyosho Graphite plates
Topcad 6 Spoke Wheel with Tire
Topcad Aluminium Front Top Plate
Topcad Front Spring Set
Kyosho Mono Shock
Topcad Motor Mount
Topcad Pinion Gear
Topcad Side Damper Set
Topcad Stabilizer Set
Kyosho Steel Kingpin Set
Topcad Toe-In Linkage Set (2°, 3°)
Topcad Wheel Nuts - 4PCS
Kyosho Ball bearing set
Kyosho clear chassic
Kyosho x-speed motor
Topcad ball diff
Nice! Yes, like le-manz said, TopCad, Eagle, and some RCRM parts are identical, seemingly made by the same factory and just packaged under different brands. le-manz, if you have the means, I'd be interested to know the weight of your Mini-Z with those parts installed. Some of the part prices on that site seem really high, are Mini-Z parts really that expensive over there?
I have no means of measuring the weight, but if I come across some, sure thing. It seems to have gained quite a bit because of all the metal parts, but it runs a lot straighter compared to out of the box. For races, i'd think i go for the stock motor mount and strip of the side damper, which doesn't seem to do a whole lot. It makes the rear end a lot stiffer for sure, but with a wide carbon H-bar, i'd guess it's the same. Has anyone tested these setups with similar parts?
Yep, the prices are pretty high, probably because the mini-z is just starting to catch on, so there is not a lot of parts coming "to town" from the far east, I'd guess....
