Old 2009.12.24, 11:31 AM   #61
kryten
kryten's Avatar
USB to 232 drivers
There you go,courtesy of Reaper.
Old 2009.12.24, 07:36 PM   #62
ub0211042
ub0211042's Avatar
Originally Posted by kryten View Post
USB to 232 drivers
thanks u guys...
Mini-Z AWD 2.4Ghz 94mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
Old 2010.02.24, 08:58 PM   #63
seanp2k
Couldn't we just use a cheap USB to TTL 5v converter such as this from Digi-Key: http://parts.digikey.com/1/parts/164...32r-5v-we.html ?
seanp2k is offline   Reply With Quote
Old 2010.07.28, 09:39 AM   #64
civilian
Tukang Pangsit
is anyone know about the software which can set ICS directly from a PDA?
coz is not easy go play mini-z bring the pitbox along with a laptop riding a scooter...
If you're car is fast, sooo fast compared to other;
either you're a drag racer or just idiot.
drag racer only go straight.
idiots do the same, coz they can't steer!
civilian is offline   Reply With Quote
Old 2010.11.21, 05:47 AM   #65
Joel2010
Joel2010's Avatar
USB to 232 drivers
another driver if above not works:
http://cid-239e3a317a793bfb.skydrive...To%20Rs232.zip
Joel2010 is offline   Reply With Quote
Old 2011.04.23, 02:53 AM   #66
Bodom
Bodom's Avatar
I made myself ICS cable following this thread and it works fine
Thank you dabinn!
Old 2013.02.08, 10:22 PM   #67
hi wondering what were the issues with using the USB adapter? which ones exactly work? thanks for any replies
Old 2013.02.11, 05:42 PM   #68
Juggler
Juggler
Juggler's Avatar
Send a message via ICQ to Juggler Send a message via MSN to Juggler
Just built it!Great info and help in this thread!Thank you!!!
GAME OVER
Insert coin
credits 0
Juggler is offline   Reply With Quote
Old 2013.02.11, 09:42 PM   #69
nice to hear... were you able to program the reverse delay response?
Old 2013.02.12, 05:05 AM   #70
Juggler
Juggler
Juggler's Avatar
Herman no...only the EX chassis gives you this option.I set the nutral wide and v.inertia off instead,and today i'll check the results on the track!
By the way i found on the ebay wire assembly with those JST ZH 4pins and i got 10 set!
GAME OVER
Insert coin
credits 0
Old 2013.04.16, 07:12 PM   #71
speedyracer
speedyracer's Avatar
awesome thread
Hi and thanks very much for this info...
I have not read this thread in entirety because I'm in the middle of something
Will this work for MR-03 Tiki Tiki chassis board?
speedyracer is offline   Reply With Quote
Old 2013.04.16, 07:18 PM   #72
TheSteve
VE7FM
Yes it will.
Old 2013.04.19, 11:06 AM   #73
speedyracer
thanks ub
Just realised my laptop doesn't have a serial port and i almost complete constructing this...
I have to buy usb to serial converter i suppose
Old 2013.05.04, 09:52 AM   #74
speedyracer
Dissapointed that i couldn't get the ics cable to work.
I asked the help of an electrician to construct it for me using the schematics found in this thread.
As you can see from the picture it's constructed very neatly (however neatly doesn't guarantee correctness, sure).
Can you please point me in the right direction using the multimeter how to test the transistor whether it's positioned right or not?
I haven't asked him yet if he tested whether the B,C,E parts of the transistor is positioned right ( i use 2N3904 transistor btw). But I believe he did follow the drawing as a guide and the picture clearly shows which side is rounded and which side is flat.
I don't know what went wrong but it just not working.
Why did the mini-z cross the road?
Old 2013.05.04, 03:46 PM   #75
TheSteve
VE7FM
I'll take a look for you and compare to the schematics but you'll need to get better pictures, use macro mode if you have it.
Hacking the ICS cable ianc 2.4GHz ASF System (Auto Selected Frequency) 28 2009.04.15 04:49 PM
resetting ICS without the cable, program? tosh 2.4GHz ASF System (Auto Selected Frequency) 2 2009.04.04 09:55 AM
Stupid I.C.S. questions... cowboysir Beginner Questions 2 2009.03.27 07:42 AM
