Old 2017.02.13, 06:56 PM   #1
Mughal86
Gear mesh issue?
Hello, I am a new user on this forum but have been collecting and racing mini-z's for awhile now. I recently purchased the ASF buggy and put a 48t atomic ball bearing standard motor in it. After a few minutes of running it at half throttle the motor was getting very hot (110 degrees). I noticed that the buggy does not coast when you push it by hand, it has some resistance unlike my Ma-020 and Mr03's( which glide when pushed by hand to check mesh). Almost feels like it is binding but when driving it there is no abnormal noise and seems to perform fine. Is that normal? I do not recall how the buggy felt with the stock motor in it.
I have ordered alloy motor plates and mount for the buggy, since I thought it would be useful for this motor.
Mughal86 is offline   Reply With Quote
Old 2017.02.14, 11:17 AM   #2
What gearing are you using with the motor? Did you change the size of the pinion/spur when you switched to the ATM Stock motor?
You could try a smaller pinion and see if it helps reduce heat.
It may take a little time for the motor to break in, and wear the brush a little. This will help reduce drag on the motor. This motor has more drag than the Kyosho motors. The brush springs are stiffer, and the magnets are MUCH stronger. 110f is a little high for what I would want to see.
Old 2017.02.16, 10:40 AM   #3
Mughal86
With the stock motor I had it geared at 7.7:1(15t pinion 33t spur). It was fairly cool even after 10-15 min run time. That is what I currently have in the buggy with the Atomic 48t motor. Maybe I should run 8.88:1(13t pinion 33T spur)? Along with the motor heat sink and alum motor plates the temps should drop with this gearing. I run it on a RCP track mini 96 with the expansion kit. Should I change the slipper clutch due to increase power of motor? Or should the stock slipper clutch be ok? Any other mods recommended to increase drive train efficiency?
Help with gear mesh. thestug Mini-Z AWD MA-010, MA-015 3 2011.04.07 04:41 PM
Getting the correct gear mesh littleleon Mini-Z AWD MA-010, MA-015 6 2010.03.10 12:03 PM
Stock AWD Gear Diffs - Dry or with 15k grease? Felix2010 Mini-Z AWD MA-010, MA-015 12 2009.08.10 12:05 AM
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 09:12 AM
Help again, trying to mesh pinion gear w/ diff gear!!! walds11 Beginner Questions 2 2003.06.11 05:06 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
[09/23/14] shop.tinyrc.com: New Atomic,... : Hey Racers!
It's been a busy week here at shop.tinyrc.com.  Plenty of new and re-order products have been rolling in along with some - more»
